Basic Wiring Outlets And Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 05-04-2011, 01:23 AM   #1
Basic wiring outlets and switches
My electrician called last minute and my drywallers are coming to close up some rooms. I have to finish off a couple of outlets and switches and just want to get confirmation that this will be ok and my logic works. Keep in mind that I am totally new to this and will have an electricial make the connections.
Power => 12-2 wire => switch => 12-3 wire => light => 12-2 wire => outlet => 12-2 wire => switch => 12-3 wire => light => 12-2 wire => outlet => 12-2 wire => outlet.
I hope that makes sense. Thanks!
ravageiwise is offline   Reply With Quote
Old 05-04-2011, 01:34 AM   #2
Rewards Points: 512
Not really, guy. What are you trying to do?
With the 12/3, are you going to be switching any lights or outlets (receptacles) at two different locations?
So, you have:
2 Switches
2 Lights
3 Outlets?
What types of switches do you have?
Old 05-04-2011, 01:44 AM   #3
Hi,
The switches are single pole and the reason for this odd configuration is because it spans a couple of really small rooms and a small hallway. There is no 3-way happening but figured I needed the 3 wire to keep the power moving in the circuit so the outlets were not switched.
And actually I realized that there is a 4th outlet which I would place after the first light. Perhaps there is a better plan. Sorry for such a lame question.
Old 05-04-2011, 02:22 AM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,922
I get what you're doing, and it sounds right. The convention is to use the red conductor in the 12/3 for the switched conductor and black for the constant hot. It is a bit unusual to run things as you've described, though. More typically, the receptacles would all be strung together and each light/switch would branch off from a nearby receptacle. It generally saves wire and is easier to run that way.
mpoulton is offline   Reply With Quote
Old 05-04-2011, 02:41 AM   #5
Ohhh, ok, I think I get it. So in that case I would run all of the 12-2 to all outlets from the power and then run 12-2 to the switch out of a nearby receptacle and then again 12-2 to the light or do I need 12-3 in that setup?
Old 05-04-2011, 02:58 AM   #6
You got it. No 12/3 needed at all unless you want to prewire for fans at the light locations, in which case you just run 12/3 from the switch to the light. I'd recommend it if you think there's any chance someone might want a fan there someday.
Tags
lights , outlets , switches
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 08:49 PM
Question about wiring and voltage with switches and lights rswurth Electrical 17 06-20-2010 11:12 PM
Replaced some switches and outlets, now some lights don't work DWooderson Electrical 3 02-02-2010 12:06 PM
Replaced outlets, now wall switches don't work? PittsburghPaul Electrical 3 08-09-2009 05:50 PM
replacing old outlets and switches Nailpounder Electrical 7 04-28-2008 09:36 AM
