Basic Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 10-06-2009, 03:22 PM   #1
Question
basic wiring
Hi!
A very basic question. I don't know much about electrical, but I am wiring a new bedroom in the basement. I ran 14-2 wire from the panel to the light switch in the new room, leaving enough spare wire can I now cut the wire and then run wire from the switch to the plug and cut the wire then run it to a wall mounted light then cut the wire then to another plug and cut the wire then to another plug and cut the wire then to another plug and cut the wire, leaving enough spare wire everywhere. An electrician told us what wire we needed, and he is going to hook everything up I just want to make sure I have the wire run the way it is supposed to be.
digimapper
digimapper is offline   Reply With Quote
Old 10-06-2009, 04:14 PM   #2
When you say plug do you mean receptacle? So you ran S-R-L-R-R-R? If so, it won't work correctly. At least not with 14-2 wire.
jerryh3 is offline   Reply With Quote
Old 10-06-2009, 04:26 PM   #3
WaldenL's Avatar
Rewards Points: 268
Sorry, doesn't sound like it, unless you want all the plugs (receptacles, things you plug something into) controlled by the switch. Do you? At it's most basic, a switch controls the flow of electricity to everything after the switch. By putting the switch first on the circuit it will control not only the light, but also all the receptacles. A "typical" installation would go from the panel to the receptacles and then to the switch and then to the light.
WaldenL is offline   Reply With Quote
Old 10-06-2009, 06:15 PM   #4
Code05's Avatar
Rewards Points: 1,104
I agree with what they said. No Code violations, but you are not going to be happy with the results.
Code05 is offline   Reply With Quote
Old 10-06-2009, 06:18 PM   #5
I also only run 12g wire for a 20a circuit for outlets
And if a bedroom you need this protected by AFCI
Is your intent that the switch going to control all the outlets?
That's about your only option with the way you are running the wire
Old 10-06-2009, 06:31 PM   #6
Thumbs up
Basic Wiring, (Agreed)
Walden L (Poster #3) had it right. Also, taking Scuba Dave,s remark that if this circuit serves a bedroom/s you will have to stick an AFCI (circuit breaker) in the panel!(No matter what)Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 10-06-2009, 07:31 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
Sorry, but as confusing as this post is, I don't see a question.
I have my own questions. What is it exactly you think you will be saving by running the wire, yet not having any clue at all what wire to run?
No offense, but you obviously have no idea what you are doing. Why bother?
Old 10-06-2009, 08:07 PM   #8
You must feed the light with a separate cable from the switch box.
Everything else can be looped together in any fashion.
220/221 is offline   Reply With Quote
Sunset Basic Home Wiring cover is wrong? CareBear Electrical 3 09-03-2009 11:31 AM
Basic wiring question Rbutch Electrical 4 05-27-2009 06:36 AM
Basic Wiring Diagram Questions mfleming Electrical 12 12-03-2008 03:05 PM
Looking for a book on basic wiring Lonicera Electrical 8 04-08-2008 11:39 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
