Basic Wire Needs For Replacing My AL Branch Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 11-29-2009, 11:59 AM   #1
Rewards Points: 79
Basic wire needs for replacing my AL branch wiring
Getting ready to take on a project to add a new subpanel off of my existing panel, add some circuits, and start replacing the AL branch wiring in my 1500 sq ft house. This is what I was planning to pick up for wire/cable/etc to start with, and was wondering if anyone can tell me if I'm missing anything obvious. This is just based on the local box store sizing. I'll compare with an electrical supplier before I actually purchase.
200 AMP/42 slot main breaker/main lug convertible panel
- running as a sub for now, but will eventually convert the service to 200 and make this the main service panel.
1000' spool of 14/2 for lights
1000' spool of 12/2 for recepts
250' 14/3 for smokes
250' 12/3 for kitchen recepts
500' 12 ga solid THHN - black
500' 12 ga solid THHN - white
500' 12 ga solid THHN - green
The THHN is for some 1/2" EMT that I'll be running in the garage and basement. I won't need nearly that much, but it's cost prohibitive to buy by the foot at the box stores.
Anything that I've missed (other than boxes, switches, etc)? All of the "big" items (furnace, water heater, etc) have been replaced within the past 10-15 years and seem to have been switched to copper as they were replaced.
I will have this all permitted and inspected, etc.
Thanks,
Mike
tigereye is offline   Reply With Quote
Old 11-29-2009, 12:20 PM   #2
Licensed electrician
Rewards Points: 1,870
You may find it cheaper to install a main breaker panel instead of the convertible panel.
I would advise against trying to use the 12-3 for the kitchen receptacles. Shared neutrals and GFIs don't play well together. just run 2 runs of 12-2 the the countertop circuits instead.
Pickup an auxillary ground bar kit for your grounds.
You have not mentioned the feeder cable or breaker to feed the new panel.
Old 11-29-2009, 12:22 PM   #3
Scared Electrician
Saturday Cowboy's Avatar
I wouldn't use 12/3 for my kitchen recps. I hate trouble shooting this kind of install because somebody will have for got to break a tab, Also the shared netural can cause phantom tripping of GFCI's if not installed real careful.
Instead to fulfill the requirement of two 20a countertop circuts in the kitchen I recommend running two 12/2 romex cables all the way from the panel. And putting for example all of the plugs to the left of the sink on one, and all plugs on right another. Or what ever way is best to split the plugs up.
Don't forget staples, Ground screws and wirenuts
And so it goes, R
Saturday Cowboy is offline   Reply With Quote
Old 11-29-2009, 12:23 PM   #4
Scared Electrician
Type to Slow
And so it goes, R
Old 11-29-2009, 12:59 PM   #5
Don't forget the drywall screws, 1x4 backing and 20 minute mud for all the cuts/patches
PS. That's a LOT of romex for a 1500' house.
220/221 is offline   Reply With Quote
Old 11-29-2009, 01:07 PM   #6
skidrowpete
Rewards Points: 12
2008 code no shared nuetrals dont forget pigtailing all nuetrals in kitche garbage disposel and dishwasher cannot be hooked to two dedicated kitchen circuits 2008 code almost everything in house is arc fault if not gfic if your jurisdiction has accepted arcfaults and all cicuits in bedrooms must be arcfault including lights and smoke detectors getting more complicated all the time
skidrowpete is offline   Reply With Quote
Old 11-29-2009, 01:24 PM   #7
Could you please supply the Code Article that prevents this?
Old 11-29-2009, 01:59 PM   #8
Rewards Points: 79
I'd second this. We're on 2005 code currently, but see no reason not to use 2008 code if it's applicable. Other than the kitchen (which I'll happily not do as it'll save me from buying the 12/3), the only other shared neutrals I had planned were the garage and basement circuits in the EMT, so I can just as easily pull a second white for each.
Mike
Old 11-29-2009, 02:03 PM   #9
Rewards Points: 79
2008 code no shared nuetrals dont forget pigtailing all nuetrals in kitche garbage disposel and dishwasher cannot be hooked to two dedicated kitchen circuits 20 08 code almost everything in house is arc fault if not gfic if your jurisdiction has accepted arcfaults and all cicuits in bedrooms must be arcfault including lights and smoke detectors getting more complicated all the time
In addition to the 2 counter circuits, I plan to run dedicated circuits for the DW, Disposal, microwave (in a cabinet), and probably fridge.
Also planned for AFCIs for all of the bedrooms, and a room in the basement that could be used as a bedroom by the next owner (assuming they want to install an egress window). Waiting to hear from my inspector regarding the AFCIs for the smokes, because I know that seems to be a local decision.
Old 11-29-2009, 02:08 PM   #10
Rewards Points: 79
Agree, it's probably way too much. I'm open to suggestions for cuts as well as additions.. ;-) I figured that a 1000' spool would be easier to work with than a bunch of 250' rolls, but willing to be told differently on that as well. :-)
Fortunately I've got either direct access and/or above or below access to most everything in the house with the exception to the garage, which is getting the EMT, so am hoping to minimize the number of repairs that need to be done in the "habitable" part of the house.
Old 11-29-2009, 02:13 PM   #11
Rewards Points: 79
Sorry, I didn't mention the feeder or ground bar. I had assumed those, but probably should have listed them. I think I've actually got the feeder cable already from the old double GFI/hot tub breaker that I'm taking out to replace with the feeder for the new panel. I'll probably feed the sub with a double 60, and need to check the size on the cable. I think it's #6, but otherwise, I'll probably pick up 10' of #4 (cable or wires) for a feeder.
Old 11-29-2009, 02:48 PM   #12
The 2008 NEC requires a period at the end of each sentence. Anyway, I believe the only change in 2008 is the requirement of simultaneously disconnecting all ungrounded conductors of all multiwire branch circuits
jerryh3 is offline   Reply With Quote
Old 11-29-2009, 03:11 PM   #13
Just go with the 250' rolls and take back what you don't open. Just uncoil the cable or build a simple spinner.
In my professional opinion, splitting up lights and receps is a waste of material and labor.
If you have access from below, the receps and switches on exterior walls will be much easier to access than the slab houses out here.
If you have plastc nailed on boxes it will be pretty easy to pull them and fish in the new wiring.
2008 code no shared nuetrals dont forget pigtailing all nuetrals in kitchen
The 2008 NEC requires periods at the end of each sentence
Old 11-30-2009, 01:15 AM   #14
Scared Electrician
Correct that is the only major change to multiwire circuts. Also required is that they be grouped. tho with Romex this is not a problem.
This is not a code requirement. Tho you will need to keep all nuetrals from AFCI's, and GFCI's seperate to and from each said device.
And so it goes, R
Old 11-30-2009, 01:18 AM   #15
Scared Electrician
Also from experience to avoid nussance tripping of AFCI's, and GFCI's, don't splice neutrals of different circuts together. ie. if two circuts are in one box be sure to maintain their neutrals seperate.
And so it goes, R
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 06:09 AM
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 06:07 PM
Basic wiring question Rbutch Electrical 4 05-27-2009 05:36 AM
Dimmer wiring in a box with 3 black and 3 white wires and a pink wire to boot! everender Electrical 9 02-15-2009 09:24 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
