Basic Switch Wiring ?? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-15-2013, 09:25 AM   #1
Rewards Points: 205
I have a switch box (2 switches) with a feed coming in. There are separate feeds going to the light and an exhaust fan. The prior electrician (termed used loosely) had three way switches on the fan and light. It was wired such that either the light would work of the fan would work but neither simultaneously. He also had the neutrals switched.
I need to rewire this
After isolating which hot and which neutral go to which device, how should I wire this with two switches that are independent? Do I need a jumper? I just can't seem to wrap my brain around the proper configuration.
Thx.
CosmicMiami is offline   Reply With Quote
Old 02-15-2013, 09:42 AM   #2
Take the hot wire (black) coming in from the feed and pigtail (i.e. use a wirenut) it to 2 black wires one going to each switch. This will give each switch its own independent power.
clydesdale is offline   Reply With Quote
Old 02-15-2013, 11:00 AM   #3
Rewards Points: 205
Done. Thanks. That's what I was figuring but wanted to make sure. I tied the neutrals together. Works like it should. Now on to the next one that the idiot did incorrectly.
What's the standard on length of stripped wire in a wire nut?
Help Wiring Dimmer Switch scubakathy84 Electrical 2 12-21-2011 10:26 PM
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 07:54 PM
Fitting dimmer switch to old electrical wiring hugomax69 Electrical 0 01-29-2010 07:40 PM
Switch on K&T wiring - OK to pigtail? fdmillion Electrical 4 01-27-2010 09:15 AM
4 way switch wiring ponch37300 Electrical 9 02-16-2009 09:58 AM
