Basic Question Regarding Switch Replacement... - Electrical - DIY Chatroom Home Improvement Forum
Old 02-19-2014, 07:24 PM   #1
Basic question regarding switch replacement...
I'm trying to replace some ugly, broken light switches (circa 1976) and noticed there are four wires connecting them and only two terminals on the new switches. The old ones have a red, black, white (neutral) and ground connecting them, whereas the usual basic switch is similar to the new ones, with just a hot loop and the black, out to the fixture. Do I need to find a switch with three terminals plus a ground for this replacement?
Thanks in advance,
82ndpara
82ndpara is offline   Reply With Quote
Old 02-19-2014, 07:27 PM   #2
Rewards Points: 758
Yes, you need to find a 3-way switch, not the single pole switch that you have.
This fixture should be able to be controlled from at least 2 locations.
AandPDan is offline   Reply With Quote
Old 02-19-2014, 07:38 PM   #3
Thank you! That makes perfect sense since all the ones with four wires are all two-location light switches.
I don't know why this didn't occur to me, as I've seen the thre way switches before.
Thank you very much....
82ndpara
Old 02-19-2014, 07:41 PM   #4
Rewards Points: 758
Pay close attention to which wire goes to the dark screw on the old and new switches. It's the common. Mix them up and you'll have problems.
Old 02-19-2014, 07:50 PM   #5
Licensed electrician
Rewards Points: 1,622
Also the white is not a neutral.
Old 02-19-2014, 07:54 PM   #6
Oh, OK, I'll be paying close attention to that,
thanks again!
Old 02-19-2014, 07:58 PM   #7
@ Jimport: Thanks for clarifying that, I just found out it is also load carriying in this scenario...
Cheers,
82ndpara
3 Way Switch Question -Please help cbagnas Electrical 51 06-14-2013 05:32 PM
Radiant heater thermostat switch wiring question tumblinman Electrical 12 07-11-2011 10:05 PM
3 Way Switch Issue (after replacement) mpukit Electrical 11 09-20-2010 03:12 PM
3 way switch question bfan781 Electrical 4 03-24-2010 11:57 AM
Another 3-way switch question. perpetual98 Electrical 10 07-21-2009 11:16 AM
