Basic Question About Panels - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2010, 10:08 AM   #1
Rewards Points: 91
Basic question about panels
Help me out here. I have 200 amp service. I have a 100 amp sub panel coming off main panel. When I add up the breakers in the main they are greater than 200 and when I add up the breakers in the sub they are greater than 100? however no tripped breakers. I am thinking that if ALL circuits were in use I would trip a breaker? I suppose my question is how can I have a 200 amp panel but the total amps for all breakers together is more than 200
drjay9051 is offline   Reply With Quote
Old 08-27-2010, 10:14 AM   #2
Licensed electrician
Rewards Points: 1,494
Adding up the handles has nothing to do with the actual load each breaker is carrying at any one time. It also does not take into account items like air conditioning and heat that are not used at the same time. A 20 amp countertop receptacle circuit may only power the coffee maker clock most of the time. You should have 2 of these circuits, but are not using anywhere close to 40 amps. The same applies for other circuits in your house.
Old 08-27-2010, 10:48 AM   #3
I have a 200a main, (2) 100a subs & a 60a sub
If I add up all my breakers it comes to ~1500a maybe
What you do is a whole house calc to determine overall electric use
My whole house calc comes in at 142a
That includes 2 full kitchen setups, hot tub, pool pump plus more
See this thread for an excel spreadsheet whole house calc
NEC- National Electric code 2008
Basic door question sbattisti Remodeling 11 08-29-2010 05:22 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
Some basic question about roofing help! motd0iyeuem Roofing/Siding 6 12-19-2005 07:15 AM
