Basic Question About Adding More Lights. - Electrical - DIY Chatroom Home Improvement Forum
Old 04-27-2013, 11:36 AM   #1
Rewards Points: 200
Basic question about adding more lights.
Hello! I have a question regarding adding more lights. My basement is very dark and there's only two lights on the one side, which is turning into more of a finished basement on this side (other side is a workshop, laundry, etc.)
Question is this. I want to add two more lights to the existing two in the ceiling. I did a very basic drawing to tie in a visual. Also, I did some reading about the overall load of the circuit. This circuit is on 20 amps, so based on some reading I did online in conjunction with what's connected to the circuit (just seems like it effects a handful of lights, no outlets at all), it seems like I have some headroom. But I do understand I have to do some more wattage calculations to make sure I still have the proper headroom needed. This question is more about whether or not I can even do what I'm brewing up in my mind.
Here's the image:
http://imgur.com/qP11cVE
Red dots = existing lights.
Black lines = existing wiring.
Yellow dot = light in other side of basement that the lights from the finished side are connected to.
Green dot = electrical box.
Blue dots = new lights I want to install.
Blue lines = new 14/2 wiring I want to install.
Can I add them in this demeanor? I just wasn't sure if I can branch off quite like this.
Thanks for the insight!
roasted is offline   Reply With Quote
Old 04-27-2013, 11:47 AM   #2
Licensed electrician
Rewards Points: 1,622
If the circuit is 20 amps you cannot use #14 wire. You need #12.
Other than that it will work as long as the boxes have enough stated capacity for the new cables.
Old 04-27-2013, 10:31 PM   #3
Rewards Points: 200
Thanks for your quick response! I pulled this up on my phone when I was in line at the hardware store. Had to run back because I had no 12-2. Saved me a trip! Thanks again.
Adding Additional Recessed lights to existing jay235 Electrical 5 11-08-2012 05:43 PM
Adding wiring for under cabinet lights from a three way switch Dale8 Electrical 0 10-07-2012 02:50 PM
Adding switch for cabinet lights - 15a switch? hyunelan2 Electrical 15 04-30-2012 12:15 PM
Wiring new lights in garage Question Tyus4 Electrical 92 02-13-2011 11:46 PM
Adding Mudroom in exisiting garage - Foundation question screamon demon Building & Construction 2 02-02-2011 12:30 PM
