Basic Multi-meter Questions - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-25-2012, 11:34 AM   #16
Rewards Points: 1,514
A reminder. Turn off the power to the circuit before doing ohms (resistance; continuity) measurements. Also at least one of the two places (wire, terminal) you touch a probe to should have everything else unhooked from it before you do the ohms test.
Old 12-25-2012, 10:13 PM   #17
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Also if your meter has a hold button make sure you don't accidentally push it before testing a circuit knew a guy that got knocked off a ladder because he pushed the hold button and nothing showed when he checked the circuit.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 12-26-2012, 08:17 AM   #18
TTW
TTW's Avatar
If you are testing a circuit to make sure it is dead before working on it, a safety check, you should always do a 3 point check.
1- check voltage on a circuit that you know is hot (confirm meter set up right and working)
2- check circuit you will be working on to ensure no voltage
3- check same live circuit you checked in # 1 to ensure meter still working / setup properly
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-26-2012, 11:26 AM   #19
Rewards Points: 129
What is the purpose for these pinchers?
I understand that the pointy end can be used to clip onto a wire,
but I don't see how you connect the probe into the base of this clip.
There's nothing but a little "blade" of contact metal inside the base hole. *
Do you just touch the probe to that little exposed blade?
I was expecting there to be some way to clip the probe onto this extender.
So, what is even the point of this whole thing?
Is the purpose to just serve as an extension probe in case your probe can't reach the wire?
Or is the point the spring loaded clip, in order to secure a hard to reach wire/contact?
Mathlete is offline   Reply With Quote
Old 12-26-2012, 11:35 AM   #20
JOATMON
ddawg16's Avatar
Rewards Points: 1,834
Those are 'make your own' wire pinchers....you have to solder a wire onto the end.....
If you pull on that cap, it will come off.
Old 12-26-2012, 11:36 AM   #21
JOATMON
ddawg16's Avatar
Side note.....I bought my 19 year old son a cheap HF multimeter for Christmas....he now has the official job of testing batteries for everyone....
Old 12-26-2012, 11:45 AM   #22
TTW
TTW's Avatar
I believe you can stick the probe of your meter right into that hole on the top, looks like it will only go in one way.
Don't think it's a "solder and make your own"
Old 12-26-2012, 11:47 AM   #23
JOATMON
ddawg16's Avatar
You might be right.......worth trying...
The Following User Says Thank You to ddawg16 For This Useful Post:
TTW (12-26-2012)
Old 12-26-2012, 04:46 PM   #24
What is the purpose of these two pinchers?
Press in the large end like a pushbutton so a tiny hook comes out of the small end and you can clip that onto a wire as one of your two test probe locations.
I think this kind of pincher uses a meter probe cable with an end called "banana plug". That is a metal stud a little less than 1/8 inch in diameter with thin springy metal flaps lengthwise against it. That plugs into the large end after you clipped the small end onto the test subject wire. Some meters have sockets on their front panels that take banana plugs in which case you need a cable with banana plugs on both ends.
Old 12-28-2012, 12:49 AM   #25
Rewards Points: 240
Does it have a hole in the "blunt" end? If so, it just slides on over the probe tip. Those things are mainly for use when testing electronics -- the little grabbers are good for grabbing component leads.
fa_f3_20 is offline   Reply With Quote
Old 12-28-2012, 12:51 AM   #26
Rewards Points: 129
The probe tip doesn't fit into the butt end hole in any cohesive way.
These things make to sense to me beyond clipping at the pointed end, but having to push the hold the connection at the butt end with the hole.
Honestly, it seems like that way is harder than just holding the probes onto whatever you're trying to measure.
Useless junk.
Grounding Questions ZBat910 Electrical 61 09-09-2011 02:45 PM
Very Basic Questions... Need Help dmen Electrical 17 12-30-2010 03:15 PM
Installing a generator: basic questions secutanudu Electrical 20 07-04-2010 06:47 PM
Water meter aggravations Ultrarunner2017 Plumbing 8 03-21-2009 06:53 AM
replacing toilet...basic questions mcvane Plumbing 4 01-16-2009 10:11 AM
