Old 01-13-2011, 01:43 PM   #1
basic code question
I need to install a single pole 120v switch in an interior wall. Is it acceptable to wall fish a single run of 14/2 NM cable to the switch using both black and white conductors as hot (with ground to the switch) and then tie it into a junction box in the attic?
deko is offline   Reply With Quote
Old 01-13-2011, 02:13 PM   #2
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
basic code question
Yes it is acceptable to do that.
When you tie into the hot wire in the 'J' box just wrap a little black tape around the insulation of the white wire.
Andy.
AndyGump is offline   Reply With Quote
Old 01-13-2011, 02:20 PM   #3
basic code question
great. thanks for the reply.
Old 01-13-2011, 02:26 PM   #4
Chicago, IL
Michael Thomas's Avatar
basic code question
If this is what you are referring to:
then it's fine.
(Diagram by DIYChatroom poster Stubbie, from his post # 11 here.)
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs
Michael Thomas is offline   Reply With Quote
R311.5.2 HEADROOM stairway code in Michigan question DoobieG Building & Construction 13 01-29-2010 06:55 PM
garage / bedroom wiring code question 205bhamjim Electrical 4 01-20-2010 10:55 AM
Code question redrumliny Electrical 14 09-04-2009 03:58 PM
"Common Path" limits for Romex -- Code question burro Electrical 4 08-10-2008 04:43 PM
Basic wood cutting question sharding Carpentry 4 08-02-2008 05:56 PM
