Basic Circuit Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 11-12-2013, 04:40 PM   #1
Hi!
I'm new to electricity, though I'm currently making a circuit in which a mini usb port is connected to and charges a supercapacitor. The supercapcitor is also connected to a buzzer, switch and LED. The supercapacitor powers those thing when it's charged. My question is, if I were to wire the mini USB port to the supercapacitor, would it be okay if I just soldered wires on to that existing circuit? I've added some a picture below. Also, when I solder things together,do I solder them positive to positive, negative to negative,in that pattern? Thanks a ton for your help!
Accipitrade is offline   Reply With Quote
Old 11-12-2013, 05:05 PM   #2
dmxtothemax's Avatar
Rewards Points: 5,098
You might want to put a current limiting resistor in between
the super cap and the usb.
A fully discharged discharged super cap will put a large load
on the usb lines, possibly too much.
I am sure there is a limit as to how much current you can pull
from the usb lines.
dmxtothemax is offline   Reply With Quote
a few basic questions? dsec123 Electrical 6 04-02-2013 10:52 AM
Some basic plumbing questions - Answers appreciated:) amodoko Plumbing 11 11-21-2012 06:47 PM
Kitchen circuit re-design - Existing is a mess darlingm Electrical 5 12-31-2011 10:45 PM
Service Panel Basic Questions Monkey100 Electrical 14 11-13-2008 05:55 AM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
