Basement Wiring Diagram Review - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-03-2010, 03:26 PM   #16
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
I would suggest you make your bottom of stair switches 3way or 4way as appropriate and then add game room switches to the top of the stairs. Also gameroom lights should be able to be turned on/off when entering/exiting the bedroom. Think nighttime, somone going to bathroom from bedroom and lights are off. You dont want them to need to walk across the gameroom to turn on a light. Or similarly, going to bed, turning off the lights then walking across a dark room.
Also, for gameroom, kids will leave on the lights. putting switches at the top of the stairs will make it easier to shut down the gameroom lights.
I agree about doing everything in 12/2. I did some work in an area where that was required. Yeah, 14 is easier to work with. I'll admit, i didn't follow that advice when doing my basement. I had a couple lighting circuits on 14. I did all the outlets on 12 tho.
Brik is offline   Reply With Quote
Old 03-03-2010, 03:55 PM   #17
joed's Avatar
Rewards Points: 11,614
12/3 is a good idea for the overhead room lights. It gives you the option of installing a fan/light in the future.
Old 03-04-2010, 01:50 PM   #18
Silky
Thank you for the idea of putting a game room light swithch outside the bedroom - I totally missed that concept! I also agree that it may be a good idea to put a switch for the game room at the top of the stairs, but that part of the house is pre-existing and I don't want to re-work it. I think it is not too bad to just have a game room light switch at the bottom of the stairs. Thanks again, you saved me a lot of work of having to go back later and add a switch by the bedroom door.
majesticjess is offline   Reply With Quote
Old 03-04-2010, 02:05 PM   #19
Handyguy
Brik's Avatar
I'm just suggesting the top of the stairs because I did exactly what you are doing. I didn't want to re-work the top of the stairs, cut into the drywall, etc.
Everytime my kids (or me, or my wife) leave the lights on I kick myself. It wouldn't have been that much more work to pull some additional wire, put in a bigger box and patch some drywall. I'm the one who usually worries about the lights getting left on or there is discord cause I yell at the kids to go turn them off (not really but that's what dads are supposed to do, right?)
For me to do it now will involve a LOT more work and expense. I have looked into special programmable switches that can be controlled without special wiring but that's expensive and potentially complicated and unreliable.
Anyway, good luck.
-Brian
Last edited by Scuba_Dave; 03-04-2010 at 06:37 PM. Reason: removed advertising links
Correct wiring diagram for 1 story house jdm001 Electrical 63 06-24-2010 05:35 PM
wiring 3 way switch for basement juliotjs Electrical 2 09-19-2009 06:24 AM
wiring diagram question screenporch21 Electrical 10 11-30-2008 09:14 PM
can you review this diagram jheavner Electrical 17 10-12-2008 11:37 PM
Safest and most efficient way to run wiring in a basement? drh Electrical 6 01-07-2008 10:04 AM
