Basement Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 12-23-2010, 02:35 PM   #1
Basement wiring
Trying to make sure I'm understanding a couple things related to a basement wiring project I'm undertaking. Basement is half finished. Finished side has a drop down ceiling. The stud cavities are left open on the unfinished side.
1. I was told by an electrician that it is against code to use romex cable above a drop down ceiling. However, in doing Internet research, it appears this does not apply to residential, single family homes. Am I correct? I'm in IN so not sure if it could be a local code trumping the NEC.
2. Let's assume I use romex. Some of my wiring will enter switch and receptacle boxes located in the stud cavities between the finished/unfinished side. Since the wiring will be exposed on the unfinished side (stud cavities are open), I imagine this would be a code violation? I imagine my solution would be to either use conduit/bx cable in those spaces or cover up the exposed wiring with drywall or paneling.
Thanks for help in advance.
Atskodinski is offline   Reply With Quote
Old 12-23-2010, 02:43 PM   #2
Rewards Points: 150
Unless local code says otherwise you can use NM above suspended ceilings in residential construction. As far as I know you can still use NM even though it will be exposed in certain portions of your basement. Covering it with drywall, etc would be a good idea though.
Steelhead is offline   Reply With Quote
Old 12-23-2010, 02:58 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
Not an issue that I'm aware off.
If that was the case, then many, many inspectors passed my work, and they are never wrong!
Old 12-23-2010, 03:04 PM   #4
Makes me wonder why he said I couldn't use NM...
I meant to make mention that I do plan to properly use staples through the stud cavities...and above drop ceiling for that matter.
Advice needed for Basement Wiring hazey313 Electrical 6 10-05-2010 12:02 AM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 10:29 AM
Basement Wiring Questions whirly Electrical 8 03-30-2009 01:52 PM
Wiring for new basement, design help jthawkins Electrical 20 03-06-2009 02:23 PM
