Basement Wiring? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-03-2008, 08:39 AM   #1
basement wiring?
I'm running wiring between joists in the basement, but when I cross 1 or 2 joists there are round heat ducts in the way, should I run the wiring on top of the heat ducts or below it?
Does it matter?
therookie is offline   Reply With Quote
Old 03-03-2008, 11:02 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
Does it matter?
Whichever is easiest for you!
jbfan is online now   Reply With Quote
Old 03-03-2008, 12:27 PM   #3
Res Ipsa Loquitur
Does it matter?
No!
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 03-03-2008, 01:51 PM   #4
www.handyguyspodcast.com
Does not matter AFAIK
I don't think it matters. I like to run below because it is easier.
Paul
borninpa is offline   Reply With Quote
Old 03-04-2008, 09:59 AM   #5
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
Run the wire to the side of the ductiong that will give you the most clearance from a nail. If you are putting down hardwood floors upstairs and can't get more than about 3/4" away from the subfloor in ALL places that the wire will travel, run it underneath. There are a lot of nails in flooring and pose too many chances of piercing a wire.
jcalvin is offline   Reply With Quote
Old 03-04-2008, 10:04 AM   #6
When is fishing season?
CowboyAndy's Avatar
My thoughts about running it on TOP of the ductwork is this: when the heat is on and that duct warms up, the warm air is going to rise, creating a higher temp above it than below it, and if there are cables up there it will make the ambient temp higher. I am not saying it will get above 75*c, but it wil be significantly warner. How many cables and how close they are could also be a factor.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 03-04-2008, 04:14 PM   #7
Electrician
Does it matter?
I generally stay below this way if you ever replace the floor it will less likely get hit, and I drill the holes at a angle so its easier to pull the wire.
chris75 is offline   Reply With Quote
Old 03-04-2008, 04:15 PM   #8
Electrician
Originally Posted by handyman78 View Post
Does it matter?
No!
actually it could...
Wiring for half bath in basement ELurie Electrical 5 08-06-2011 09:06 PM
Safest and most efficient way to run wiring in a basement? drh Electrical 6 01-07-2008 09:04 AM
Basement wiring hotrod Electrical 17 07-14-2006 07:01 PM
basement elecrtical wiring jscholl411 Electrical 1 05-23-2006 09:55 AM
wiring a basement ITE Electrical 3 04-13-2005 07:20 PM
