-   -   basement wiring? (http://www.diychatroom.com/f18/basement-wiring-17943/)
therookie 03-03-2008 08:39 AM
basement wiring?
I'm running wiring between joists in the basement, but when I cross 1 or 2 joists there are round heat ducts in the way, should I run the wiring on top of the heat ducts or below it?
Does it matter?
jbfan 03-03-2008 11:02 AM
Does it matter?
Whichever is easiest for you!
handyman78 03-03-2008 12:27 PM
Does it matter?
No!
borninpa 03-03-2008 01:51 PM
Does not matter AFAIK
I don't think it matters. I like to run below because it is easier.
Paul
jcalvin 03-04-2008 09:59 AM
Run the wire to the side of the ductiong that will give you the most clearance from a nail. If you are putting down hardwood floors upstairs and can't get more than about 3/4" away from the subfloor in ALL places that the wire will travel, run it underneath. There are a lot of nails in flooring and pose too many chances of piercing a wire.
CowboyAndy 03-04-2008 10:04 AM
My thoughts about running it on TOP of the ductwork is this: when the heat is on and that duct warms up, the warm air is going to rise, creating a higher temp above it than below it, and if there are cables up there it will make the ambient temp higher. I am not saying it will get above 75*c, but it wil be significantly warner. How many cables and how close they are could also be a factor.
chris75 03-04-2008 04:14 PM
Does it matter?
I generally stay below this way if you ever replace the floor it will less likely get hit, and I drill the holes at a angle so its easier to pull the wire.
chris75 03-04-2008 04:15 PM
Originally Posted by handyman78 (Post 103881)
Does it matter?
No!
actually it could...
