Basement Wiring - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-29-2012, 11:17 AM   #16
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
AFCI's would not be required for the heater or dryer, only lighting/receptacle circuits. There is no limit on the number of receptacles on the circuit, however, 23 is MUCH more than I would put on one single circuit.
Old 07-29-2012, 12:00 PM   #17
Rewards Points: 1,500
Originally Posted by vitma View Post
@AllanJ: do I need to mark feeder wires in each box somehow (in case someone else need to do electrical work in the basement)? Also - is there any "unofficial" rules on how to run wires to each switch box (for example - feeder wire should always come through top left hole, etc). )?
No rule about feeder entering from the top left, etc.
Marking of the cables is needed here only during the time you are connecting things up. Just to keep the switches and cables for the different banks of lights from being confused with each other. If the labels are still readable when you are done, no harm leaving them there.
AllanJ is online now   Reply With Quote
multiple light switches on existing basement Wiring fdasilva Electrical 8 05-31-2011 09:30 AM
Basement Electrical Wiring Question psqually Electrical 11 05-15-2011 04:18 PM
Advice needed for Basement Wiring hazey313 Electrical 6 10-04-2010 11:02 PM
Basement Wiring Questions whirly Electrical 8 03-30-2009 12:52 PM
Wiring for new basement, design help jthawkins Electrical 20 03-06-2009 01:23 PM
