Basement Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 08:29 AM   #1
Basement wiring
The electrician I hired to wire my basement went out of business so I can't get an answer from him. I finished an office downstairs and went into the light switch box to hook up a switch for lights and found 3 sets of Romex going into the box. I am confused. I was expecting 2. I am figuring the 3rd might be the smoke detector that is in the room? I need lights!! I doubt all 3 get hooked up to the single switch but what do I know. Please help if you can. Thanks.
lphudock is offline   Reply With Quote
Old 11-01-2011, 08:32 AM   #2
Licensed electrician
Rewards Points: 1,020
You might have a power in, a power out and a cable running to the lights. Are any splices made in the switch box?
How many cables and what kind are in the box for the smoke alarm?
Old 11-01-2011, 08:47 AM   #3
Thanks for the quick response. I can't see what comes from where any longer since it is behind drywall. The 3 whites are wire nutted together as are the grounds.
Old 11-01-2011, 09:17 AM   #4
If you are comfortable you could install a single pole switch temporarily to see if you can get the light to work. This may take a couple of tries. The black that does not get used would still need to be figured out. A toner to follow that black might help.
Old 11-01-2011, 09:36 AM   #5
Electrician
SD515's Avatar
Rewards Points: 504
Is there 1 black wire wrapped around the other 2, or vice-cersa?
Kyle
Old 11-01-2011, 06:59 PM   #6
No problem
the whites are all connected together
what about the blacks? where are they going?
longspur is offline   Reply With Quote
multiple light switches on existing basement Wiring fdasilva Electrical 8 05-31-2011 10:30 AM
Basement Electrical Wiring Question psqually Electrical 11 05-15-2011 05:18 PM
Advice needed for Basement Wiring hazey313 Electrical 6 10-05-2010 12:02 AM
Basement Wiring Questions whirly Electrical 8 03-30-2009 01:52 PM
Wiring for new basement, design help jthawkins Electrical 20 03-06-2009 02:23 PM
