Basement Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 02-05-2013, 09:54 PM   #1
Rewards Points: 87
basement wires
I am finishing my basement. I have replaced those metal conduits with romax and plan to build a soffit for them to stay for easy access.
I didn't drill holes and just attached them to the bottom of the joists. Is this ok? Do I need to staple them to the bottom of the joists? Please tell me anything wrong there.
It is not done yet, that big conduit will be replaced next weekend.
basement wires-img_9336.jpg   basement wires-img_9338.jpg   basement wires-img_9339.jpg
diy001 is offline   Reply With Quote
Old 02-05-2013, 10:06 PM   #2
Rewards Points: 13,300
Go back and add your location to your profile, some areas require it to be run in conduit.
Whole lot harder to finish out the basement with it runs like that.
Old 02-05-2013, 10:24 PM   #3
Engineer
Rewards Points: 161
Hope you're not in the Chicago area
diystephen is offline   Reply With Quote
Old 02-05-2013, 10:24 PM   #4
Rewards Points: 87
even inside the covered soffit?
Old 02-05-2013, 10:28 PM   #5
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Yes some areas require it.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-05-2013, 10:33 PM   #6
Rewards Points: 87
I am in MA.
Old 02-05-2013, 11:20 PM   #7
Blank
Looks like classic DIY electrical work...
Baxter01 is offline   Reply With Quote
Old 02-06-2013, 06:51 AM   #8
eastcoastsparky's Avatar
Rewards Points: 150
You could of saved time and bored holes to pull wire, those hangers are usually used in commercial buildings with mc cable
eastcoastsparky is offline   Reply With Quote
Old 02-06-2013, 07:08 AM   #9
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I would consider those cables to be bundled and they would need to be derated. If you are building a soffet, they can be stapled to the bottom of the joist.
Old 02-06-2013, 08:25 AM   #10
Rewards Points: 1,442
What are the wire nuts in the panel for? Not illegal in most places, but yehck.
mikegp is offline   Reply With Quote
Old 02-06-2013, 11:58 AM   #11
Rewards Points: 87
that's temporary. they will be removed later.
Basement moisture/humidity issues amason2308 Remodeling 2 09-12-2012 09:27 AM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 11:09 PM
Running from outside service panel into basement ksl420 Electrical 0 03-21-2011 12:30 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 08:07 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 09:49 AM
