Old 10-08-2012, 09:47 AM   #1
Basement Rough-In
I contacted my local inspector about what to do with the main panel and this is what I got "All outlet boxes shall have joints made up , with a minimum of 6 inch pig-tails. No devices to be installed."
In the rough-in for the panel what is usually required? Do I connect the grounds and neutrals inside the panel with no circuit breaker and if so what happens to the hot wire? Where should I put it in the panel so it does not interfere with all the live wires?
buildit45 is offline   Reply With Quote
Old 10-08-2012, 09:51 AM   #2
Electrical Contractor
Basement Rough-In
When using an exsisting panel, I instll the grouonds and the neutrals.
Install the breakers, and put wire nuts on the hots until I finish.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 10-08-2012, 10:18 AM   #3
Lic Electrical Inspector
electures's Avatar
Basement Rough-In
Please refer to post #13 in this thread.
DIY Electrical work in New Jersey
Even though I started the thread aimed at New Jersey, a lot of it applies everywhere.
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
Rough in for Basement TBolt Plumbing 8 12-13-2011 06:56 PM
New rough opening to basement - spiral staircase benjamincall Building & Construction 8 07-16-2010 06:53 PM
Basement wall issues. Need rough idead of fix. meltdowndave Building & Construction 6 10-03-2009 12:24 PM
Basement bathroom rough in plumbing ferris13 Plumbing 5 09-28-2009 11:06 AM
Best way to clean rough basement concrete floor Red Squirrel Flooring 3 09-21-2009 07:47 AM
