Basement Rough In - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2012, 10:57 AM   #1
Rewards Points: 674
Basement Rough In
I am currently doing the electric rough in for my basement. At this stage I want to allow for easy future changes. One of the changes I want to allow for is to an electric dryer. I currently have and plan to keep using my gas dryer. I want to run a separate circuit for the dryer to allow for an electric dryer in the future. However, I do not know what type of wiring todays electric dryers require.
Question: should I run 12/2, 12/3, 10/2, or 10/3? I will keep using my gas dryer and run it on a 20 Amp breaker. Distance is minimal and I have all wire.
B
Beepster is offline   Reply With Quote
Old 08-02-2012, 11:08 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 528
10/3 with a ground on a 30 amp breaker is pretty normal.
jbfan is online now   Reply With Quote
Old 08-02-2012, 12:04 PM   #3
Rewards Points: 674
That's what I was figuring. Put that in and push the red off to the side in the panel.
Thanks.
B
Old 08-02-2012, 01:39 PM   #4
Rewards Points: 29
Make sure you put in a big enough box at the dryer. A dryer receptacle will not fit in a standard single gang box.
cube17576 is offline   Reply With Quote
Old 08-02-2012, 01:56 PM   #5
Rewards Points: 674
That's good to know. I was going to have a double box, and have both the dryer and washer plugged into it, each on separate circuits.
So I need to have the washer circuit in a separate box from the dryer circuit? What type of box would I need for the dryer circuit? Being I only have a gas dryer now and no plans to buy an electric dryer, I do not know what type of receptable I would have. Are they all the same for electric dryers? Could I just run 10/3 to its own box now and if upgraded in the future, a new "old work" box could be put in?
B
Old 08-02-2012, 04:11 PM   #6
There's no need to have the washer and dryer on a separate circuit. Put your existing washer and dryer on a single circuit and have a second box there with the electric dryer receptacle in it for the future. A normal 2 gang box will work fine for this.
Calc is offline   Reply With Quote
The Following User Says Thank You to Calc For This Useful Post:
stickboy1375 (08-02-2012)
Old 08-02-2012, 04:11 PM   #7
"So I Re-Wired It"
MisterZ's Avatar
There are a few different styles for dryer recepticles.
If you plan on installing a flush mount recep., you'll need a separate box.
They are a bit larger, and im not sure if a standard cover plate would fit.
Since this is a hypothetical future install, you may consider a surface mount recep. when the time comes.
This way you just remove the 20amp recep. and run the 10/3 thru the back of the surface mount one.
Another option, install a flush mount dryer recep next to the 20amp one.
Now youre set up for either design.
Knowledge is Power, but 240v can Keel You!!
MisterZ is offline   Reply With Quote
Old 08-02-2012, 04:22 PM   #8
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Seriously, it's that easy.
I use these for dryers and ranges...
The Following User Says Thank You to stickboy1375 For This Useful Post:
jbfan (08-02-2012)
Rough in for Basement TBolt Plumbing 8 12-13-2011 05:56 PM
New rough opening to basement - spiral staircase benjamincall Building & Construction 8 07-16-2010 05:53 PM
Basement wall issues. Need rough idead of fix. meltdowndave Building & Construction 6 10-03-2009 11:24 AM
Basement bathroom rough in plumbing ferris13 Plumbing 5 09-28-2009 10:06 AM
Best way to clean rough basement concrete floor Red Squirrel Flooring 3 09-21-2009 06:47 AM
