Basement Renovation - Electrical - DIY Chatroom Home Improvement Forum
Old 01-17-2011, 09:17 AM   #1
Basement renovation
I am doing a basement renovation and had a question with the wiring layout for my lighting. I am going to have 9 lights total on the same circuit which will include 7 pots which should not exceed my max voltage on one 15amp breaker. The current lights are wired to a double gang box at the bottom of my steps controlling the basement lights and a light at the base of the steps. My pic shows how I want to run my lighting using the existing wiring but I have a concern over how many wires I will have running out of the 2 gang box. Currently it has 4 wires for the 3 way switch and basement lights, I need to add two more to split up the lighting to the other rooms. Im sure they would all fit in the box but would this setup be to code or would I have to rethink my wiring and centralize the live wire from my break to ease the amount of wiring per box? My location is Ontario. Help would be greatly appreciated, Thanks
sketchy is offline   Reply With Quote
Old 01-17-2011, 09:41 AM   #2
I=E/R
a7ecorsair's Avatar
I see 6 cables and I assume there will be two devices (switches). #14 counts 2.0 per wire and each device counts 4.0 All grounds count as 2.0 and all internal clamps count 2.0
6 x 2 = 12
Gnds = 2
Dev. = 8
clamps =2
So it looks like you need a 24 cu in box if I have everything..
a7ecorsair is offline   Reply With Quote
Old 01-17-2011, 11:55 AM   #3
joed's Avatar
Rewards Points: 12,902
The three way switch will need a three wire cable so 2 more for the extra wire.
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Basement Bathroom Renovation zoso13 Building & Construction 1 10-22-2010 06:26 AM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Sunlight for a Basement Room prglor Remodeling 1 08-31-2008 04:29 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
