Basement Receptacle Under Service Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 05-11-2006, 01:49 PM   #1
Basement receptacle under service panel
When I was building my house, I installed an outlet under my service panel which was temporarily connected to a breaker in order to supply our tools while building. I have since removed the outlet but now I need an outlet there again. Since the panel is in the basement, behind hinged wooden panels, is there a conflict with the code if I install a receptacle in that location under the service panel? I could locate a nearby circuit which has less than 12 units on it and wire it into that circuit. Or could I wire it directly to another circuit breaker in the panel? Is a 15A circuit breaker allowed to have two wires connected to it? thanks for the advice.
mekanic is offline   Reply With Quote
Old 05-11-2006, 10:27 PM   #2
Don't put 2 wires under 1 breaker, use a wirenut.
Not sure what you mean by 'hinged wooden panels'
Sparky Joe is offline   Reply With Quote
Old 05-12-2006, 05:41 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
I myself would not add it to an existing circuit, especially one with already over ten devices.
As long as the hinged panels expose all the electrical components you are OK.
You can put two wires under newer Square D QO & HOM breakers, and most newer Cutler Hammer CH breakers.
Best bet though for a DIY is to pigtail so you are sure.
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Main Service Panel Full bobo Electrical 5 09-24-2007 07:13 PM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 10:00 PM
meter to service panel mikim Electrical 5 05-04-2007 05:34 AM
Arced main lug in service panel burgeke Electrical 4 11-02-2006 11:28 AM
