Basement Receptacle Requirements - Electrical - DIY Chatroom Home Improvement Forum
Old 02-14-2014, 07:57 PM   #1
Rewards Points: 506
Are 15 amp receptacles allowed in unfinished basements?
Are they allowed in finished basements?
What's the norm, if no Code requirements?
I know they must be GFCI in unfinished.
Installation is the Reverse of Removal.
Old 02-14-2014, 08:09 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Yes
Yes
Depends on local amendments.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 02-14-2014, 08:09 PM   #3
Licensed electrician
Rewards Points: 996
Yes to both. Why do you think they would be prohibited?
Old 02-14-2014, 09:21 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
In the states, in a home, there is little to no reason for a 20 amp receptacle.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
electures (02-15-2014), stickboy1375 (02-15-2014)
Old 02-14-2014, 10:11 PM   #5
Rewards Points: 455
I disagree
Cletis is offline   Reply With Quote
Old 02-14-2014, 11:15 PM   #6
Rewards Points: 506
I was thinking about the use of the basement as a work space with power tools.
I reckon there's no reason they should be.
Old 02-15-2014, 11:20 AM   #7
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by Cletis View Post
I disagree
I've only needed maybe two in my career, one was for a treadmill, I think the other was a central vac....
Old 02-15-2014, 10:03 PM   #8
jbfan's Avatar
Rewards Points: 138
I disagree
Are you going to defend the statement or just let it ride?
Tell me why I am wrong!
Old 02-15-2014, 10:13 PM   #9
Banned Electrician
HARRY304E's Avatar
Rewards Points: 204
I disagree
Why?
Give one good reason...
HARRY304E is offline   Reply With Quote
Old 02-15-2014, 10:19 PM   #10
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
For his sybian of course....
The Following User Says Thank You to k_buz For This Useful Post:
stickboy1375 (02-17-2014)
Old 02-15-2014, 10:27 PM   #11
jbfan's Avatar
Rewards Points: 138
Missed that one!
Old 02-15-2014, 10:32 PM   #12
k_buz's Avatar
Yeah, he posted the thing drawing 6.3 A @240V and wanted to know if it should be considered a continuous load.
Old 02-15-2014, 11:47 PM   #13
Rewards Points: 506
OK, thanks, guys.
NOW, I need to use PVC for sleeving the Romex down the wall from joists. Should be only one cable per sleeve, and the questions are:
Schedule 80, rather than 40, must be used, correct?
What size PVC would satisfy #12 and #14
I will have at least one 10/3 for a 30 amp dryer
Old 02-16-2014, 12:07 PM   #14
electures's Avatar
Originally Posted by sirsparksalot
OK, thanks, guys. NOW, I need to use PVC for sleeving the Romex down the wall from joists. Should be only one cable per sleeve, and the questions are: Schedule 80, rather than 40, must be used, correct? What size PVC would satisfy #12 and #14 I will have at least one 10/3 for a 30 amp dryer
Or EMT. Size depends on number of conductors or cables.
Old 02-16-2014, 08:44 PM   #15
Rewards Points: 506
One cable of 12/2 max in each pvc.
Basement Finishing Plan phoray Remodeling 3 12-20-2013 02:14 PM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
Basement Cooling BTU requirements? neilt HVAC 5 05-29-2010 04:26 AM
Adding a receptacle in the basement Bigplanz Electrical 1 11-11-2009 06:31 PM
