Basement Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 10-22-2011, 02:40 PM   #1
basement questions
I have wired a new circuit for my basement. I have the permit and I am awaiting the rough inspection. One wall had drywall that was not taped, just screwed. I removed the drywall and installed the boxes and wiring. The wall has insulation, do I need to remove it for the inspection?
Also, there is an existing light switch at the top of the stairs for the unfinished portion where I am installing the outlets. There is none at the bottom of the stairs or in the unfinished part itself. There is a three-way switch for the finished area top and bottom of stairs.
Do I need to have a three-way switch for the unfinished area? If so, does the bottom switch need to be in the unfinished area? If not, can I take the existing wire that leads to the switch at the top of the stairs and re-route it to the unfinished area (inside of it) and just have that one switch? If possible, the last would be my preferred route.
I appreciate any insight.
Boongoon is offline   Reply With Quote
Old 10-22-2011, 03:02 PM   #2
Code05's Avatar
Rewards Points: 1,104
You only need to remove enough insulation to expose the wires.
If I understand you have two 3 ways for the stairwell and finished area. and 1 single pole at the top of the stairs for the unfinished area.
You want to reroute the single pole to the unfinished area.
If so, yes.
Unfinished area receptacles require GFCI protection
Code05 is offline   Reply With Quote
Old 10-22-2011, 03:15 PM   #3
Thanks. The insulation is stapled and I kind of just pushed the isulation away, not really removed. You cant see all the wiring unless you push aside the insulation. Shouls i just remove it? I would probably have to buy new if I do, but the cost isnt that great.
Great on the light switch.
Yes, I am installing the first recepticle with a GFCI so the whole run will be protected?
Old 10-22-2011, 03:33 PM   #4
Code05's Avatar
The inspector may be happy enough as long as he/she can see the bored holes and stapling near the box. I would wait and see what he/she says, but it could be demanded that full exposure is required. Never cover up before inspection.
A GFCI protects receptacles that are downstream and connected to the load side terminals.
Old 10-22-2011, 03:39 PM   #5
Thanks for your advice.
Evan
Basement Trap and confused questions Ryan7 Plumbing 15 02-26-2011 10:42 AM
Adding heat to a basement, newbie questions frizbplaya HVAC 3 01-28-2011 02:57 PM
Older basement shower needs remodel. Questions about showers and concrete blocks. speedster1 Remodeling 6 01-28-2010 02:55 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 08:49 AM
basement bathroom rough in - framing questions twobabieslater Building & Construction 2 12-29-2008 02:56 PM
