Basement Pod Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2013, 09:24 AM   #1
basement pod lights
Hi,
I want to install some pod lights in my basement, and would like to know how many I should install and at what distance from each other. the dimension of the room is 18 feet 8 inch by 13 feet 8 inch. I will be puting drop ceilling, and the heiht of the ceilling will be around 7 feet. This area will be use as a play room for my little girl and movie room for us, therefor will be installing a dimmer switch. I found the type of pod lights that I will be using, there are 4 inch round pot lights. Also will be buying these Energizer PAR20 LED bulbs.
http://www.canadiantire.ca/AST/brows....jsp?locale=en
With this info, can you guys tell me:
1- How many pod lights should be installed
2- How far apart should the pod lights be installed from each other
3- How far apart should the pod lights be installed from the walls
DanCom is offline   Reply With Quote
Old 01-02-2013, 04:43 PM   #2
eastcoastsparky's Avatar
Rewards Points: 150
Wherever you want there isnt a code on that, have fun and be safe, ask questions if your unsure
eastcoastsparky is offline   Reply With Quote
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 01:35 PM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
Basement lighting circuit - multiple lights and switches, end of circuit cmyk Electrical 2 03-03-2011 03:39 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
Recessed Lights for Basement nthomp16 Electrical 2 02-13-2008 04:54 PM
