-   -   basement pod lights (http://www.diychatroom.com/f18/basement-pod-lights-168020/)
DanCom 01-02-2013 08:24 AM
basement pod lights
Hi,
I want to install some pod lights in my basement, and would like to know how many I should install and at what distance from each other. the dimension of the room is 18 feet 8 inch by 13 feet 8 inch. I will be puting drop ceilling, and the heiht of the ceilling will be around 7 feet. This area will be use as a play room for my little girl and movie room for us, therefor will be installing a dimmer switch. I found the type of pod lights that I will be using, there are 4 inch round pot lights. Also will be buying these Energizer PAR20 LED bulbs.
http://www.canadiantire.ca/AST/brows....jsp?locale=en
With this info, can you guys tell me:
1- How many pod lights should be installed
2- How far apart should the pod lights be installed from each other
3- How far apart should the pod lights be installed from the walls
eastcoastsparky 01-02-2013 03:43 PM
Wherever you want there isnt a code on that, have fun and be safe, ask questions if your unsure
