Basement Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 12-14-2010, 04:37 PM   #1
Basement Outlets
I have a basement that is half finished. I am planning on putting in a few standard outlets along the wall dividing the two sides. The outlets will be facing the finished side. Issue is, there is no wall covering on the finished side so when I put in the new outlets, the backside of the outlets will be exposed on the unfinished side. Is this any sort of NEC code issue?
Atskodinski is offline   Reply With Quote
Old 12-14-2010, 07:07 PM   #2
I'm confused about u saying u want to put the outlets on the finished side but it is exposed....if its finished, what do u mean by exposed? If ur question is "the back of the outlet box will be exposed, is this legal per the nec?" Then ur answer is yes
heartlessmcfly is offline   Reply With Quote
Old 12-14-2010, 07:26 PM   #3
Sorry, should gave been more clear.
Yes, backside of the outlet box is what I meant.
Old 12-14-2010, 07:27 PM   #4
Ur fine...
Old 12-14-2010, 07:33 PM   #5
Rewards Points: 150
I'm sincerely hoping the outlets are going to be in boxes and not just screwed to the wall.
Assuming they're in boxes, yes, fine. Otherwise, stop playing with wires before you hurt someone.
emolatur is offline   Reply With Quote
Old 12-14-2010, 10:16 PM   #6
Yes, in boxes. Apologize for not being clear enough. Thanks for the advice.
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Definition of a finished basement vs. unfinished hectorlopez Building & Construction 2 01-31-2010 08:31 AM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 08:49 AM
basement issues - tile, mastic, moisture pfisch Flooring 6 12-01-2008 01:35 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
