Basement Outlet By Sump Pump Stopped Working - Electrical - DIY Chatroom Home Improvement Forum
Old 12-07-2010, 01:27 AM   #1
Basement Outlet by sump pump stopped working
About 6 months ago I noticed my sump wasn't on in my basement.
I plugged it in to another outlet across the room and it worked fine. The outlet it was plugged into just stopped working.
My house is 100 years old too. It doesn't seem like a fuse has blown.
What could this mean? Am I in harm's way? What should be done?
crypty9 is offline   Reply With Quote
Old 12-07-2010, 06:58 AM   #2
Could be loose wires, bad contacts in the outlet, fuse not making good contact in the fuse box, etc. If you still have a fuse panel, it should be updated to breakers.
Old 12-07-2010, 07:34 AM   #3
Master Electrician
Rewards Points: 3,778
Is the outlet GFCI protected upstream?
brric is offline   Reply With Quote
Old 12-07-2010, 07:36 AM   #4
Rewards Points: 1,216
Is the pump on a GFCI circuit? Plug a lamp or something in to the outlet and try to find out why there's no juice, unless you have a tester use that.
COLDIRON is offline   Reply With Quote
Outlet not working, reading "open ground" syren Electrical 3 04-19-2010 05:20 PM
Brand new Carrier Infinity 16 Heat Pump Stopped Working I think needmyac HVAC 3 07-07-2009 07:12 PM
Sump Pump french drainage issue HomeDIYslfr Plumbing 1 05-16-2009 01:21 PM
On Off Indicator For Outside Sump Pump Lawrence Coppar Electrical 31 03-29-2009 02:01 PM
Basement Flooding / Sump Pump -- Should I get a generator added to my home. DIY_Help General DIY Discussions 9 02-20-2009 06:36 PM
