Basement Outlet Rough Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 12-30-2007, 05:33 PM   #1
Rewards Points: 324
Basement outlet rough wiring
When running wire from outlet to outlet on a basement exterior wall with insulation, can I run wire horizontally through studs or do I need to go up to the ceiling, across, and then back down stapling to the center of the studs?
tigerbalm2424 is offline   Reply With Quote
Old 12-30-2007, 06:01 PM   #2
Rewards Points: 1,442
It's perfectly OK to drill the studs and run the cable more directly from one outlet box to the next. For a stud wall against the foundation you cn drill the holes closer to the concrete side so there is mroe than the required 1-1/4 inches of wood between the front edge and the hole.
Ideally the insulation should be slit and arranged around the cable rather than leave a large air space behind the cable.
Old 12-30-2007, 07:31 PM   #3
Rewards Points: 324
Thanks! This is the part that I questioned. I figured it wouldnt make sense to drill holes in the studs and then run the insulation towards the outside of the wall and the wire would lay against the sheetrock once installed. Splitting the insulation makes sense! Thanks!
Old 12-31-2007, 09:16 AM   #4
If, after drilling the holes you have less than 1 1/4 inch from the face of the stud to the wire, you will need to put in nail plates.
Heck nail plates are cheep. Just put them up anyway. You dont want a screw in your electrical wires.
Master Electrician
jwhite is offline   Reply With Quote
Old 12-31-2007, 04:20 PM   #5
Electrician philosopher
It has always been my habit to put them EVERYWHERE in a kitchen, then as needed in the rest of the house. Cabinet installers scare me more than sheetrockers.
Andy
Andy in ATL is offline   Reply With Quote
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
Troubleshooting bedroom outlet wiring? Operator4819 Electrical 15 04-01-2007 09:10 PM
Cellar to rough basement? javamom Remodeling 1 06-27-2006 05:23 PM
Wiring an outlet in the garden wackerjr Electrical 8 05-28-2006 09:18 AM
How to get a rough quote on a basement?? cloudkicker101 Building & Construction 4 04-18-2006 12:48 PM
