Basement Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2009, 04:39 PM   #1
basement outlet
My basement has outlets attached to the floor joists (overhead). I would like take off one the wood and swing one down to mount it on the cinder block wall so its easier to get at. Can it be attached directly to the wall or should it be mounted on a board attached to the wall. there is enough wire to bring it down about a foot. An electrical inspector looking at all the wiring so I'd like to do it correctly.
Dave
dnn1942 is offline   Reply With Quote
Old 04-24-2009, 04:46 PM   #2
Union Electrician
goose134's Avatar
Yes, you can attach it to cinder block. Try and find a hollow part of the cinder block ( they look like a Roman Numeral 3) from above. Blast a 1/2 inch hole and toggle it right to the block. If the block is filled, you can try a tapcon. Use a shorty, the long ones tend to strip out the material and not hold. I'd think maybe a 1" or 1 1/4" will do you.
goose134 is offline   Reply With Quote
Old 04-25-2009, 05:07 AM   #3
Rewards Points: 894
If the basement is unfinished, you will need a GFCI receptacle. Actually, if unfinished, I think ALL of the receptacles need to be GFCI protected.
FW
Ultrarunner2017 is offline   Reply With Quote
Old 04-25-2009, 08:08 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Just use 1" Tapcon screws or plastic anchors. This way all you need is a 1/4" or 3/16" hole.
You are not hanging a 500lb cabinet.
Old 04-25-2009, 09:08 AM   #5
Bsm't outlet
Hi
Thanks for all the suggestions.. they will help. My only concern now is there any code requirement for a outlet mounted on a masonry wall it will be used for a sump pump. the cord will not reach once the pump in down in the sump hole. I don't believe I I can use an extension cord , here in new jersey anyway!
Tahnks
Dave.
Old 04-25-2009, 10:52 AM   #6
Chicago, IL
Michael Thomas's Avatar
Originally Posted by dnn1942 View Post
Hi
Tahnks
Dave.
No extension cords per manufacturer's instructions, every one will say something like:
Also, prohibited in the NEC
Also, a Bad Idea - when I find an extension cord at a sump pump at inspections it's sometimes disconnected or clearly in danger of becoming so.
The 2008 NEC eliminated the GFCI exception for sump pumps in unfinished areas of basements, 120V units must now be GFCI protected
Home Inspection: "A business with illogically high liability, slim profit margins and limited economies of scale. An incredibly diverse, multi-disciplined consulting service, delivered under difficult in-field circumstances, before a hostile audience in an impossibly short time frame, requiring the production of an extraordinarily detailed technical report, almost instantly, without benefit of research facilities or resources." - Alan Carson
Michael Thomas is offline   Reply With Quote
Old 04-25-2009, 10:56 AM   #7
Rewards Points: 160
The sump pump should have it's own cord and plug. You can order/buy them with varying cord lengths. Just put the receptacle where it will reach. You can leave the original receptacle where it is, then branch out and install a new box and device. This will need to be on a GFCI protected circuit.
There is no issue mounting boxes to cinder block or concrete walls. It is done all the time. As mentioned above, simple concrete screws or screws and anchors will make for a solid install. I prefer the concrete screw.
No extension cord allowed. Extension cords are only allowed for temporary/limited use.
Old 04-25-2009, 11:55 AM   #8
Rewards Points: 894
The tapcons are great. If you get the kit, you get the drill bit with the screws.
You may want to consider running a dedicated branch for the sump pump, since its failure due to something else tripping the breaker could be a big problem.
Absolutely no extension cords!
FW
GFCI from basement laundry to outdoor outlet TPS Electrical 11 01-15-2009 12:17 AM
Multiple Circuits - Same Outlet box Revnjeff Electrical 2 09-04-2008 08:17 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Code for Outlet Placement in Basement redbandit Electrical 5 01-02-2008 10:13 AM
Basement outlet rough wiring tigerbalm2424 Electrical 4 12-31-2007 03:20 PM
