Basement Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 12-13-2011, 06:08 PM   #1
Basement Lighting
Remodeling the basement, need help laying out proper lighting. Is anyone aware of any tools that can help with lighting design?
stuff is offline   Reply With Quote
Old 12-13-2011, 06:36 PM   #2
Rewards Points: 6,652
Pencil, ruler and grid paper. Some people use Visio, or such to also layout. First step is to sit down and figure out what is already down there on circuits, what you wish to add, and give into that mix, what size is your service, and panel space available.
Old 12-13-2011, 07:02 PM   #3
The more the merrier. Lighting is key to taking the basement out of basement remodel. Put in lots of overhead can lighting. I spaced mine on every 3rd joist (48"). Track and other indirect lighting where ever you can place it is great too.
kwilcox is offline   Reply With Quote
Old 12-13-2011, 09:17 PM   #4
Exactly what i am looking for. It is hard to know how many fixtures are enough without wasting too much energy. I was hoping for some type of rule of thumb, watts of lighting per square foot or something like that. A design software tool will work as well, but i cannot find one.
I am using Visio to draw the actual circuits. Panel is 200 amps with 13 spare breaker spaces. I have plenty of room to add circuits.
Old 12-13-2011, 09:42 PM   #5
Design your branch circuits based on fixture ratings. For my basement project, I ran a separate 15A branch circuit for built-in lighting and another for the outlets in each room. 15A at 120V is 1800 watts or 30 60W fixtures max. In practice, you'll never need that many for any given room.
I'd recommend using LED lighting in your overheads since they put out a lot less heat. They are indistinguishable from incandescent if you remember to purchase 2700 K temperature equivalents.
Old 12-13-2011, 09:45 PM   #6
I don't know about rules of thumb, but I used 4 100W rated PAR 40 overheads for each 100 sq ft. I also had a 180W tracklight fixture for each 100 sq ft.
Old 12-13-2011, 09:46 PM   #7
Not a Noob or Boob
No reason to limit yourself for down the road upgrades. Go with 12ga wire and 20A circuits.
Rob1975 is offline   Reply With Quote
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 11:50 AM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 09:49 AM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 03:52 PM
