Basement Light Circuit Help - Electrical - DIY Chatroom Home Improvement Forum
Old 10-11-2011, 09:53 PM   #1
Rewards Points: 154
Hello,
I have an unfinished basement that has a light circuit shown below:
I'm replacing the junction box "B" feeding the current fluorescent light partly because I'm putting a bigger light in for my wife and partly because the current junction box looks like this:
The oddity here I think is that the line from the panel comes into junction "B" then another line is run straight to junction "D" without feeding anything in junction "B". The line feed is then switched at junction "D" and a switched feed is then looped back to junction "B" and all the other lights.
Why would it be done this way? It seems to me that it would just be easier to run the line straight to junction "D" without going through "B" or make "B" the switch point.
My main question is: when I change the box, can I leave it like this and still be kosher with Ontario code or should I move the switch loop to "B" and eliminate the line feed between "B" and "D".
Thanks, and I hope this all made sense!
pete0403 is offline   Reply With Quote
Old 10-11-2011, 10:10 PM   #2
Missouri Bound's Avatar
Perhaps some it if was added over time....and adding a line rather than running a new one was a simpler plan. Use a 4" box.
Old 10-12-2011, 08:45 AM   #3
Rewards Points: 154
So it's fine to leave the wiring as-is? (except putting in the new 4" box)
Old 10-18-2011, 06:22 PM   #4
Rewards Points: 154
I just re-did the box and left everything as-is except instead of a fixture I put an outlet up there so I could hang and plug two worklights into it.
It worked well except I cut one of the hot wires by accident in a clamp on the new box. Having a fuse blow in your hand with a loud bang and smoke from the box is not good for the heart! I won't make that mistake again
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Circuit trips with 2 light switches sylercider Electrical 3 12-05-2010 10:09 PM
Can 15 A light switch be used on a 20 A circuit? Mi Feller Electrical 26 07-22-2010 04:42 PM
Tie into existing bath GFI circuit for new basement bath GFI? 8roty Electrical 8 07-27-2009 11:38 PM
Circuit advice for finishing basement Straightgrain Electrical 16 03-25-2009 09:07 AM
