Basement Finish, Old Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-20-2012, 10:45 AM   #1
I am finishing my basement and have run into a little problem. I am using a light switch that is currently in place controlling the basement lights. I will continue to use this switch to control the lights however as you can see from the picture below the box is recessed behind my stud wall.
I do not want to rerun this line, is there any way that is up to code that I can splice this and put a new box in front of it?
buildit45 is offline   Reply With Quote
Old 09-20-2012, 10:58 AM   #2
Code05's Avatar
Rewards Points: 1,104
Do you just want to keep the switch at the same location and put drywall up?
Code05 is offline   Reply With Quote
Old 09-20-2012, 11:16 AM   #3
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Kill the power to the box,remove the box and re-attach the box so its 3/8" or 1/2" beyond stud depending on what size rock your using?
Not enough wire to move forward,move the box up a little.
sublime2 is offline   Reply With Quote
Old 09-20-2012, 11:29 AM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
Buy a mud ring for the depth of the sheetrock and however far back the box sits.
Old 09-20-2012, 11:35 AM   #5
Rewards Points: 660
Go buy a new contruction box of the proper size from Home Depot and stop being so damn cheap.
B
Beepster is offline   Reply With Quote
Old 09-20-2012, 11:35 AM   #6
Licensed electrician
Rewards Points: 1,290
Devices are not made to mount to that box. You would need to add a plaster or mud ring.
Old 09-20-2012, 12:01 PM   #7
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
OP stated that the box in the pic was already used for the switch and he wants to continue using that box. so the assumption is that the ring was removed prior to the pic being taken.
Old 09-20-2012, 02:56 PM   #8
I do not want to use the metal box for the switches. I have another box that I want to put in front of it; however in order to get enough wire in the box using the same line without a splice I have to move the box up the wall which I would rather not do. If there is an alternative that will allow me to put my box in front of this one and splice the wires to the new box that would be ideal. That way the box height does not have to change.
Old 09-20-2012, 03:23 PM   #9
Code05's Avatar
Why do you need to add another box? As already stated, there are adaptors /extensions that would work.
Old 09-20-2012, 03:42 PM   #10
Oso954's Avatar
Rewards Points: 772
You can try an extension ring. Still might have to move the box slightly. You can also put a different rise mud ring on it.
Oso954 is online now   Reply With Quote
Old 09-20-2012, 05:02 PM   #11
Rewards Points: 150
How far is that box recessed into the stud cavity? Hard to to tell from that picture.
The problem is that any splices have to be accessible. If you put another box in front of that box, it will not be accessible once the wall is closed up.
silversport is offline   Reply With Quote
Old 09-20-2012, 10:28 PM   #12
Rewards Points: 79
Mud ring and pig tails? Can't see how many wires coming in on my phone but should work if no box fill issues.
And if I understand him right
eclark is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
3 way switch layout has me confused crescere Electrical 5 09-08-2012 11:26 AM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Floor drain in finish basement zantar Plumbing 1 02-03-2011 10:10 AM
