Old 03-23-2006, 11:34 AM   #1
Basement Electrical- Flexible Conduit?
We are finishing our basement, and it is a new home, with the outside basement walls "formed" to look like brick, we are leaving the outside walls as they are (painted of course). The interior new walls are drywall.
For the walls that are the formed concrete, we'd like to add some outlets. Can we use flexible conduit to run to the enclosed boxes, or do we need to use the rigid conduit? We are in Ohio (don't know if code might be different in other states).
Thank you!
H Thomas is offline   Reply With Quote
Old 04-20-2006, 03:48 PM   #2
Flexible conduit is ususally limited to 3 ft in alot of areas. Best bet wouuld be to call your village as ask.
Renovator is offline   Reply With Quote
Old 04-20-2006, 09:42 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Most flexible conduit/tubing can be of unlimited lenght if a ground conductor is run inside. I would not recommend it though. I'd use EMT thinwall conduit or PVC sch80.
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 08:08 AM
Conduit through basement wall. bdalekid Electrical 13 01-31-2007 09:35 PM
Finishing basement - electrical code ??? normwannabe Electrical 1 01-23-2006 08:48 PM
pulling wire through old flexible conduit cbray Electrical 1 05-20-2005 04:55 PM
Running Conduit in new basement framed walls tben Electrical 3 12-11-2004 12:14 AM
