Basement Electrical Code - Electrical - DIY Chatroom Home Improvement Forum
Old 02-13-2013, 02:27 PM   #1
basement electrical code
I live in north GA and slowly finishing my basement. I have construction experience and do have some common basics about wiring.
I know, any new bedrooms must be on AFCI breakers. I actually planned on doing it in all new rooms to the basement.
I read that you have to have GFCI outlets in basement. Is that right?
Bathrooms need GFCI outlets, or anything near water.
And how many outlets can i put in a room. I planned on making everything for 20 amp.
I just want to make sure everything is correct and not fly by night.
princevlad is offline   Reply With Quote
Old 02-13-2013, 02:55 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Pretty much all areas that do not require GFI protection now do require AFCI protection. Not just bedrooms.
ALL unfinished basement areas.
Yes, and pretty much.
As many as you want. And I would do 15A for lights, but it's your call.
The Following User Says Thank You to Speedy Petey For This Useful Post:
princevlad (02-13-2013)
Old 02-13-2013, 03:12 PM   #3
thanks a bunch
Old 02-13-2013, 06:38 PM   #4
And its ok to run the outlet in the basement bathroom to the upstairs bathroom outlet that is GFCI?
Old 02-13-2013, 07:42 PM   #5
deverson's Avatar
Rewards Points: 77
You can use an upstairs recp only if the upstairs recp is the not connected to fans or lights in the bathroom.
I don't have the code reference in front of me but if you need It I can get it for you.
deverson is offline   Reply With Quote
Old 02-13-2013, 10:13 PM   #6
Yea, i think the outlet is coming of the switch or lights; In both upstairs bathrooms.
And that one outlet(GFCI protected),in the future bathroom, has to have its own dedicated breaker now?
Old 02-13-2013, 10:23 PM   #7
deverson's Avatar
Rewards Points: 77
Or, you can run a 20 amp circuit and power the entire downstairs bathroom. Lights, fan and recps.
Old 02-13-2013, 10:24 PM   #8
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You can put the entire bathroom on one 20A breaker, but that circuit cannot leave that bathroom.
Old 02-13-2013, 10:28 PM   #9
Thats what i planned on. Then read somewhere of it not being code to run the recp off of the lights now.
I am not going to be jerry riggin anything. But i will take the word of someone who knows what they are doing.
Old 02-13-2013, 10:30 PM   #10
understood
Old 02-13-2013, 10:33 PM   #11
k_buz's Avatar
Its a little bit confusing to some people...
Bathroom receptacles need to be GFI protected and on a 20A circuit. That 20A circuit can feed one entire bathroom or the receptacles (GFI) in multiple bathrooms. If the circuit contains the receptacles of more than one bathroom, it cannot contain anything but those bathroom receptacles. That circuit can never have lighting in areas not in the bathroom.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
mpoulton (02-14-2013), princevlad (02-13-2013)
Old 02-13-2013, 10:39 PM   #12
deverson's Avatar
Rewards Points: 77
Right on the money!
The Following User Says Thank You to deverson For This Useful Post:
Old 02-13-2013, 10:54 PM   #13
thanks for the fast concise replies guys. Glad i found this site.
Old 02-13-2013, 10:55 PM   #14
MarginallyQualified
Rewards Points: 2,464
Which is great until it's 0 dark thirty and the gfi trips.
Keep lights and receptacles apart.
Old 02-13-2013, 11:02 PM   #15
then there's that
New Basement Bathroom / Laundry Room Electrical Circuit(s) Rookie11 Electrical 5 12-11-2012 08:52 PM
breaker panel positioning regulations orobono Electrical 1 10-27-2012 03:25 PM
Exposed electrical wires under sink in basement Dizzle Electrical 18 02-12-2012 04:35 PM
electrical code tradtke Electrical 6 08-02-2011 11:11 AM
building code for basement 2nd staircase ninghai Building & Construction 5 01-06-2010 04:54 PM
