Basement Electrical Circuit Capacity - Electrical - DIY Chatroom Home Improvement Forum
Old 02-12-2013, 10:10 AM   #1
basement electrical circuit capacity
I'm in an old 50s bungalow and want to add 6 new pot lights to an existing circuit. The circuit currently has 4 pot lights, two wall scones and two receptacle. I'm planning to take out the two wall scones since they are not tied to a light switch. In the end I'll have 10 pot lights and 2 receptacles.
10 pot lights @ 75watt each = 750watt = 6.25A
2 receptacle @ 2amp (??) each = 4A
Total 10.25amp
The one light switch will turn on all 10 lights drawing 6.25amps.
Is it safe to keep the receptacles on the same circuit or do I need to run a new circuit just for the two receptacles. Just my vaccum cleaner already draws 10amps I believe. I guess I could vacuum in the dark
I can also use other receptacles to vaccum with but does anyone know what other appliances that will trip the breaker if I have a continuous load of 6.25 amps?
Adatwist is offline   Reply With Quote
Old 02-12-2013, 10:14 AM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Yes. Shouldn't be a problem.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Do I have any more electrical service capacity? (Power for Shed) Magnus357 Electrical 7 10-13-2012 08:52 AM
Running new circuit from basement to attic dekohl Electrical 4 03-20-2012 07:24 PM
Basement lighting circuit - multiple lights and switches, end of circuit cmyk Electrical 2 03-03-2011 02:39 PM
Circuit advice for finishing basement Straightgrain Electrical 16 03-25-2009 09:07 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
