Old 02-08-2010, 09:31 PM   #1
Default Basement circuit layout
Hello,
I am trying to size a sub panel for my basement. Below are the loads. I believe I take the total wattage and divide by 240VAC based on the fact it will be a 240V panel. I come up with 31 Amps. I have a few questions..
-Is my circuit distribution correct, are the loads/items per circuit within limits?
-What size of sub panel would you recomend?
-How can I tell that my main panel can handle this sub-panel?
Proposed sub-panel loads.
15A - 100W - Smoke Detector
15A - 1000W - Bathroom heater
15AGFI - 360W - Bathroom receptacles
15AGFI - 300W - Bathroom lights
15A - 1800W - 10 x receptacles
15A - 720W - 4 x receptacles
15A - 450W - 9 x 50W potlights (600W dimmer)
15A - 420W - 7 x 60W Wall lights (600W dimmer)
15A - 400W - 4 x 100W lights (no dimmer)
7350 Watts total.
Note: My bathroom circuits are on GFI breakers (lights and receptacles seperate...I get a deal on breaker...I know not neccessary).
Also...accounted for 180W per receptacle.
DSEIBEL1 is offline   Reply With Quote
Old 02-09-2010, 01:01 AM   #2
Licensed Electrician
Magnettica's Avatar
Send a message via Yahoo to Magnettica
Your load calcs look great. Normally it is done by the square footage of the area but what you did is fine too. Except for the bathroom receptacles that should be calculated at 1500 watts, not 360. Hair dryer 360 watts? Ok? :D
60 amp 120/ 240.
By doing a load calc according to article 220.
Union County, NJ, Licensed Electrician
Classic Electric, LLC, Rahway, New Jersey
Magnettica is offline   Reply With Quote
Old 02-09-2010, 01:03 AM   #3
Magnettica's Avatar
Also, your bathroom receptacles need to be 20 amps, not 15.
Old 02-09-2010, 08:51 AM   #4
Extreme DIY Homeowner
Scuba_Dave's Avatar
Where are you located ?
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/-ongoing-37438/
Please fill out Location in your profile (User CP), then we can answer your question
If a code reference is needed for one of my posts please access NEC 2008 & read
http://nfpaweb3.gvpi.net/rrserver/browser?title=/NFPASTD/7008SB
More On This Topic
Now it's time to turn the power back on at the circuit breaker box. This particular dimmer switch has a slider on the side. Moving the slider will change the amount of brightness of the lamp. Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip we'll be locating our power shut off. Before we can start taking down our old light we need to make sure that the power is shut off so we don't get electrocuted. The first thing we need to... Read More »
Now we are going to talk about the two factors concerning the bulb size. The first one is the maximum size of the bulb or number of bulbs you are going to use in this fixture. Your instructions will tell you that this device is good for 60 watts. In that... Read More »
Hi I am Drew Fendy, master home inspector. I have been inspecting for over 24 years. Today we are going to describe how to install an electrical receptacle for Expertvillage.com. One choice you need to make when you are planning is whether you are going... Read More »
Hi! My name is Chad Smith and I'm a state certified Journeyman Wireman basically a electrician and I'm representing expertvillage.com. Today we are installing a new doorbell in our house here. The first step that you should take when you are installing... Read More »
Trying to figure out layout in roughed in basement bathroom vseven Plumbing 19 12-10-2009 04:51 PM
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 07:00 PM
Circuit advice for finishing basement Straightgrain Electrical 16 03-25-2009 11:07 AM
Dedicated freezer circuit in basement? budde97 Electrical 5 02-15-2007 05:09 PM
layout, basement redo yellow.shoes Remodeling 1 10-20-2004 10:04 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
