Basement Bathroom Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 01-18-2011, 10:52 AM   #1
basement bathroom wiring
Hi All, I am adding a bathroom to my basement and have a couple questions about how to wire it. I have attached a drawing of bathroom. I have a light above the shower which I have been told needs to be run off GFCI. I am only planning on having the one GFCI outlet and I believe that it needs to be on its own circuit with 12 gauge wire. So I am wondering how to go about doing this?
For the rest of the lights and the fan I was just planning on running 14 gauge wire from a separate circuit. So there would just be the two circuits.
Please let me know if you can help.
Thanks!
fordross is offline   Reply With Quote
Old 01-18-2011, 11:30 AM   #2
iminaquagmire's Avatar
Rewards Points: 338
You need to have a 20A GFCI receptacle circuit. You can put the lights on it if you want but then the circuit cannot leave the bathroom. If you put the lights on the GFCI circuit, don't put them on the load side of the GFCI or else if it trips, you won't have lights. The shower is what you want on the Load side. In my own bathroom I ran two circuits but later put them together at the breaker because it didn't make sense to have two dedicated circuits IMO. My shower lights go from the switch through a dead front GFCI next to it, then to the lights.
BTW, this isn't actually an NEC requirement, just a good idea. It would only be a local amendment or a manufacturer requirement.
Also remember you must use a shower rated trim for this light.
iminaquagmire is offline   Reply With Quote
Old 01-18-2011, 11:37 AM   #3
joed's Avatar
Rewards Points: 11,964
You need to post your location. Rules are different for different locations(Canada, USA).
Old 01-18-2011, 12:04 PM   #4
Thanks,
I am in Milwaukee, WI.
Just to make sure I understand. I will have one circuit with the GFCI outlet. Then a 20A GFCI circuit that would have the shower light and the rest of the lights on it. So I would run 12 gauge wire from the GFCI circuit to the bathroom for the shower light, then a separate wire from the GFCI circuit to the bathroom for the rest of the lights? Is ok to run 14 gauge from the 20A circuit.
I am also a little confused about the dead front GFCI?
Thanks again
Old 01-18-2011, 12:39 PM   #5
Licensed electrician
Rewards Points: 1,234
On the 20 amp circuit all the wiring must be #12.
A dead-front GFI has the sensing circuitry of a regular GFI, it just does not have the slots to allow you to plug into.
Old 01-18-2011, 01:09 PM   #6
joed's Avatar
You could put the entire bathroom on one 20 circuit.
Old 01-18-2011, 05:03 PM   #7
So pretty much wire it up like this? Sorry, I am very visual person and need a picture before I be confident about this.
Thanks for all the responses!
Old 01-18-2011, 07:05 PM   #8
joed's Avatar
Why three feeds. One should be enough.
Wiring for half bath in basement ELurie Electrical 5 08-06-2011 10:06 PM
Basement bathroom rough in efrobert Plumbing 2 06-23-2011 05:54 PM
Basement Bathroom wiring? philly529 Electrical 3 02-24-2010 10:46 AM
Basement Bathroom Costs ktulu05 Remodeling 15 04-20-2009 02:24 PM
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 01:17 AM
