Basement Bath Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 02-15-2011, 08:43 PM   #1
Starting to do the rough-in for my wiring...My question is this I will be using a Leviton 20Amp -60 minute digital timer connected to our exhaust fan on a 12/2 wire, i will have 3 pot lights , light switch and a 15 amp GFCI receptacle on the 14/2 wire which branches off to only one plug on the run. Can i mix these around say putting the GFCI on the 12/2 run and the lights on a separate run?
zoolou is offline   Reply With Quote
Old 02-15-2011, 09:06 PM   #2
Licensed electrician
Rewards Points: 1,266
The receptacle needs to be on a 20 amp circuit wired with #12 wire.
Old 02-15-2011, 09:22 PM   #3
Rewards Points: 1,446
No part of the circuit may be 14 gauge.
The 15 amp GFCI receptacle is okay provided it is a duplex or there is another receptacle on the circuit and in that bathroom.
Old 02-16-2011, 01:16 PM   #4
so if i run the GFI with 20amp....can i tie the timer switch and fan to it?
Old 02-16-2011, 02:31 PM   #5
iminaquagmire's Avatar
Rewards Points: 338
You can have lights (fan and exhaust too) on the 20A bathroom GFCI receptacle circuit as long as the circuit does not leave the bathroom. Nothing NEEDS to be GFCI protected besides the receptacle(s). All wiring needs to be 12 guage as stated above.
iminaquagmire is offline   Reply With Quote
Finished basement wiring questions Badfish740 Electrical 7 12-29-2010 12:25 PM
Finishing a basement bath Vent? Pump-up toilet connection heenanp Plumbing 0 03-23-2010 07:43 PM
pre-stubbed basement bath vent needed? ameleus Plumbing 7 09-21-2008 11:26 AM
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 01:09 AM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 10:10 AM
