Old 11-02-2009, 03:43 PM   #1
Question Basement antenna using electric circuit
I recently finished my below-grade basement. I put a stereo system down there that has an AM/FM radio receiver in it. Depending on the alignment of the stars and planets, etc, I may get great reception one minute and virtually nothing the next. I was thinking that some time ago, I had heard orread that you could use you home electric circuitry as a giant antenna. Is there any validity to this? If so, how does it work? Does it require any special equipment? Is is risky or dangerous?
Woodcutter is offline   Reply With Quote
Old 11-02-2009, 03:58 PM   #2
Yoyizit's Avatar
You use a low value capacitor with a high breakdown voltage to couple the antenna to one side of the AC line. The capacitor's impedance at radio freqs. is much lower than at 60 Hz, so the 60 Hz doesn't go where it's not supposed to.
50 pF is probably enough.
It's the opposite of an RF choke.
Somewhere on the Internet is probably a schematic and parts list for one of these.
Old 11-02-2009, 06:32 PM   #3
Child Alert! Pull Up!
fltdek's Avatar
Seems like there used to be commercials on TV for a gizmo like that, you would just plug it into an outlet and it would use the electrical wiring as an antenna.....check the site "as seen on TV" or radio shack.
fltdek is offline   Reply With Quote
Old 11-02-2009, 06:36 PM   #4
What are you using for TV antenna? FM band is right between channels 6 and 7 and TV antenna will work great for FM signals.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 11-02-2009, 06:39 PM   #5
fltdek's Avatar
Then again, maybe not such a good idea - I googled "whole house antennas" and came across this link:
http://www.kyes.com/antenna/antennat...ennatypes.html
Best to do a little, or a lot of research.
Old 11-02-2009, 07:23 PM   #6
Yoyizit's Avatar
Try it.
10' of Romex makes a 1000 pF capacitor between each conductor.
One conductor goes the antenna, the other goes to one side of the AC line.
Be sure to insulate the ends so they don't touch each other or anything else.
Old 11-03-2009, 09:41 AM   #7
All of the wiring in the house will pick up radio signals but the signal picked up from one branch circuit will commingle with the signal picked up by another branch circuit and the result may either be stronger (additive) or weaker (subtractive due to cancellation). So what you get when you plug a "whole house antenna" or a "power line antenna" into a wall receptacle is a matter of luck.
A similar stroke of luck may improve AM radio reception by stringing a power cord of the radio or a lamp past the AM antenna which is generally a pencil or crayon or Magic Marker shaped and sized rod (some are fatter than others) inside or on the back of the cabinet.
A long time ago, FM radios had a so called "line cord antenna" which used the power cord as the antenna and had a strip of metal wrapped around the cord (where the cord entered the back of the cabinet) and wired to an antenna terminal. In effect this is the same thing as a $29.95 or so whole house antenna that plugs into a receptacle; the metal strip mimics a small capacitor to pass the radio waves but not pass enough to cause a shock hazard. In reality, most of the signal actually getting to the antenna terminal was picked up by the 6 or so feet of line cord itself.
The AM antenna on a stereo receiver is often just outside the back of the cabinet and a label warns not to use it as a handle. A year or so ago an inspector used a similarly shaped antenna mounted to the fuselage of an airplane to hoist himself up to get a close look at something and of course the antenna broke off.
Bait gone and the mouse trap has not snapped? Maybe ants got there first.
More On This Topic
For Expert Village, I'm Kurt Glaser, N7QJM. On today's sessions, we're talking about what actually makes up the ham radio rig, per say. There are just different names for each thing that we use. Our ham radio gear is used is actually called our rig. The... Read More »
How a CB Radio System Works
How a CB Radio System Works by Expert Village
My name is William and we are going to explain how a CB radio works. A CB radio was designed to transmit and receive a circuit. Now when you transmit into the microphone your voice is converted into a radio frequency and it is sent out of the antenna. It... Read More »
Michael Raines, Expert Village. Just like the remote control, we have to set the receiver to receive from the remote, which then, in turn, takes the signal that it receives and sends it to the wall. So now, again, we have our little box. Now, as you... Read More »
A GPS has an internal antenna built into it so that it can read satellite signals and translate them into the tracking data or maps you see on your screen. Reception can be compromised when using a GPS in closed-off locations, such as the woods, inside... Read More »
Hi I am Drew Fendy, master home inspector. I have been inspecting for over 24 years. Today we are going to describe how to install an electrical receptacle for Expertvillage.com. One choice you need to make when you are planning is whether you are going... Read More »
Circuit advice for finishing basement Straightgrain Electrical 16 03-25-2009 11:07 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 11:41 PM
Basement mhughrob Remodeling 1 07-11-2008 09:11 PM
To AC Basement or Not? jacko10 HVAC 0 09-20-2007 05:44 PM
Dedicated freezer circuit in basement? budde97 Electrical 5 02-15-2007 05:09 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
