Basement - Electrical - DIY Chatroom Home Improvement Forum
Old 03-31-2011, 07:59 PM   #1
Basement
Im wiring up my basement and was wondering if 14/2 romex would be safficiant.( keeping in mind I live on galveston island and flooding and humidity is a real problem)
Jake418 is offline   Reply With Quote
Old 03-31-2011, 08:29 PM   #2
I would use 14/2 for the lights and 12/2 for the outlets.
Jbyrd is offline   Reply With Quote
Old 03-31-2011, 08:29 PM   #3
Licensed electrician
Rewards Points: 1,622
Type NM cable is now prohibited from usage in damp areas.
Unless you used UF type cable anything that was exposed to flood water should probably be replaced.
I would call your local building official and ask if they will allow NM cable.
Old 03-31-2011, 09:15 PM   #4
Rewards Points: 1,016
I recommend the same -
The the advise of when you figure up how much wire you need compare the costs of buying a larger spool of #12 vs, buying smaller amounts of #14 and #12 - maybe about the same to go all #12.
basement causing suction on basment door BlueBSH HVAC 3 06-08-2010 02:26 PM
Basement Cooling BTU requirements? neilt HVAC 5 05-29-2010 03:26 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
