Baseboard And Water Heaters 12/2 Yellow? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-28-2013, 11:13 AM   #1
Baseboard and water heaters 12/2 yellow?
I have a situation where I only have 12/2 yellow on hand. Is it ok to use 12/2 yellow wire to hook up baseboard heaters and water heater? Or is it still required that I use only red?
murphyos is offline   Reply With Quote
Old 05-28-2013, 11:26 AM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,444
Got me confused.... what is 12/2 yellow... do ya mean the cable color of NM.
And that then begs the question, what is 12/2 red.
Is your question directed as to the AWG of the wire, or the color of uncabled THHN wire in conduit.??
MTN REMODEL LLC is offline   Reply With Quote
Old 05-28-2013, 11:46 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 150
Where are you located?
I think red colored cable is only a requirement in Canada.
jbfan is online now   Reply With Quote
Old 05-28-2013, 12:30 PM   #4
Rewards Points: 12,878
The gauge of the wire is determined by the load being placed on it.
I've never seen #12 used on a water heater unless it's a small plug in 110V, only # 10..
Old 05-28-2013, 12:31 PM   #5
Rewards Points: 18
I think the 12/2 yellow the OP is referring to has a yellow sheath with a white,a black and a bare conductor. The red sheath cable has one red, one black and a bare conductor. I don't know if recent changes to the code mandate its use.
daveb1 is offline   Reply With Quote
The Following 3 Users Say Thank You to daveb1 For This Useful Post:
Kyle_in_rure (05-28-2013), MTN REMODEL LLC (05-28-2013), Philly Master (05-28-2013)
Old 05-28-2013, 02:22 PM   #6
joed's Avatar
Rewards Points: 11,608
The red cable is not a requirement. It is only an option.
If your circuit breaker is 20 amps or less then the 12/2 yellow is acceptable.
Old 05-28-2013, 02:35 PM   #7
funfool's Avatar
Rewards Points: 534
The color of the sheathing on the wire by code changed awhile back.
I remember when it was all white sheathing, and the size was stamped in ink on the sheathing.
This made the inspectors have to actually look and read the wire sizes in a rough in inspection.
Now with the new code, the inspector can just look at the color of the wire and know what size it is without getting face into each little section to see if it is correct size.
white is 14
yellow is 12
I thought 10 was orange, but it could be red. then there is #8 wire.
None of this has anything to do with what the poster wants to do.
I have a 20 amp breaker and some #16 wire and want to connect a water heater ... is that ok
funfool is offline   Reply With Quote
Old 05-28-2013, 03:55 PM   #8
joed's Avatar
Colour changed by the manufacturer. There is nothing in the code about what colour the cable needs to be.
The Following User Says Thank You to joed For This Useful Post:
Old 05-28-2013, 04:07 PM   #9
Rewards Points: 1,192
They color coded cable so you could tell the help "Run white there, run yellow here and run orange to that".
bobelectric is offline   Reply With Quote
The Following 2 Users Say Thank You to bobelectric For This Useful Post:
paul100 (05-29-2013), Philly Master (05-28-2013)
Old 05-28-2013, 04:49 PM   #10
funfool's Avatar
Rewards Points: 534
Again is why location is important.my area and I thought would be federal and not local.
They changed the color of the wire sheathing for only 1 purpose I know of, so inspectors could identify it.
Here is a photo of what I have in my van, 12-2 use to be white and same as 14-2.
They did not mandate the 12-2 be changed to yellow because it was pretty.
Was so the inspector could stand in a room and see what different wire was being used and for what circuits.
Maybe not code, But I can not buy 12-2 in white in New Mexico for several years.
And when the poster replied he only had yellow wire lying around, this is what I am thinking of.
Baseboard and water heaters 12/2 yellow?-hpim0744.jpg
The Following User Says Thank You to funfool For This Useful Post:
Old 05-28-2013, 07:25 PM   #11
joed's Avatar
It looks pretty. Inspectors like it for the reasons stated. But it is not code unless you have a local amendment.
The red cable is called Heatex. It is used for 240 volt circuits and has red and black instead of black and white. But it is not required by code to be used.
The Following 2 Users Say Thank You to joed For This Useful Post:
jbfan (05-28-2013), Kyle_in_rure (05-28-2013)
Old 05-28-2013, 08:21 PM   #12
Neat... learn new things all the time...Thanks
Old 05-28-2013, 09:23 PM   #13
Rewards Points: 4,784
Standard Romex is white: 14, yellow: 12, orange: 10.
There are different codes in different places, but I'd be surprised to see a modern water heater that takes 12g wire. I do like the answer that if the breaker is 20amp you can use 12g. But again, I'd be very surprised to see a water heater on a 20amp circuit.
jeffnc is offline   Reply With Quote
Old 05-28-2013, 09:30 PM   #14
baseboard heater - you will have to check the specs of the heater and pick the right circuit, then wire.
always
1. current draw of fixture
2. determines circuit size
3. determines wire size
Old 05-28-2013, 09:32 PM   #15
Joed... Couple questions.... where coded or used, same ratings as Romex NM. Is it NM I guess is my question.
What guages does it come in, OP implied his red was 12... but if it's use is for 240, does it come in #10 also.
Also, is it's only configuartion 2 wire, does it come 3 wire with ground for appliances and bigger guage than 10.
Tags
wiring colours
Baseboard hot water heaters in shared hallway tedfor HVAC 1 01-08-2013 04:59 PM
electric hot water baseboard heaters. handyman_squire Plumbing 5 08-12-2012 07:14 AM
hot water baseboard heaters bubblebuddy914 HVAC 3 01-27-2011 12:31 PM
Oil powered Hot Water Radiation with Baseboard Heaters girly_momma HVAC 5 01-13-2010 10:22 PM
Removing hot water baseboard heaters. Sandy1000 HVAC 4 11-02-2008 05:41 AM
