Baseboard Power Outlets - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-15-2012, 02:43 PM   #16
Code05's Avatar
Rewards Points: 1,104
http://www.amazon.com/dp/B00303FYHS/..._df_B00303FYHS
Code05 is offline   Reply With Quote
Old 09-15-2012, 02:48 PM   #17
Rewards Points: 1,062
Originally Posted by Code05 View Post
how do you fasten this to the box itself? i don't see any screw holes on the other side, do you just insert it in and pressure-fit it?
Old 09-15-2012, 02:49 PM   #18
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You just insert, and use longer 6-32's, its pretty much self fastening.
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
amakarevic (09-15-2012), Code05 (09-15-2012)
Old 09-15-2012, 11:25 PM   #19
" Euro " electrician
frenchelectrican's Avatar
That work very well I have used few time as well as long the box opening is not eff'ed up and the orignal box is soild ya are fine with that part.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
amakarevic (09-16-2012)
Old 09-16-2012, 09:32 AM   #20
Licensed electrician
Rewards Points: 1,612
Big Orange also has a fixed depth plastic box extenders. You just buy the thickness you need and they can be grouped if needed.
No power in all three bathroom outlets hpdad Electrical 23 03-24-2012 12:51 PM
Grounding outlets... bigdaddyII Electrical 12 08-28-2011 02:22 PM
Baseboard Heater / Power Cord Problem channingg General DIY Discussions 8 10-01-2009 11:35 PM
Electrical - Outlets with no power jogan Electrical 5 05-05-2009 02:06 PM
Power to outlets but not enough? batesrt Electrical 5 02-04-2008 09:12 PM
