Baseboard Power Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2012, 02:55 PM   #1
Rewards Points: 1,062
Question
baseboard power outlets
i need to have a couple of baseboard power outlets. the problem is, and i am using metal handy boxes with side braces, they are made to be flush with the drywall and not another layer on top of it (baseboard). so i was wondering if anyone knows of some special handy boxes that are made specifically for baseboard outlets that give it more offset between the brace and the edge of the box or is there a trick to it or something.
yeah, i can always leave the box flush with the drywall and recessed a little inside the baseboard but that kindof looks ugly, especially if you don't cut the faceplate opening on the baseboard 100% correct and without gaps around. which is hard to do.
or perhaps if there is a yoke adapter that would indent the outlet outside by an offset of 3/4" or can that simply be accomplished by not screwing the yoke screws all the way in and leaving them out by 3/4" and then accomplish firmness using the faceplate screwed to it and resting against the baseboard ?
thanks
Old 09-15-2012, 02:58 PM   #2
Julius793's Avatar
thanks
You can use a 1900 box with a 1" mud ring.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 09-15-2012, 02:59 PM   #3
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
thanks
Oldwork plastic boxes directly into the baseboard. That is how I do it.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 09-15-2012, 03:03 PM   #4
the problem is that all receptacle installation must be done in the rough-in phase, i.e. boxes installed before drywall and baseboard. because then i won't be able to access the wiring.
Old 09-15-2012, 03:04 PM   #5
any issues with using just a simple metal handy box with braces for stud (or in this case, sole plate) mounting with a mud ring?
Old 09-15-2012, 03:07 PM   #6
electures's Avatar
Just poke the wires out where they will be located. Tell the inspector you are going to oldwork the boxes into the baseboard. SHouldn't be a problem. See it done all the time in old homes, historical renovations, and such. That is also how I like to do it.
The Following 3 Users Say Thank You to electures For This Useful Post:
Code05 (09-15-2012), frenchelectrican (09-16-2012), stickboy1375 (09-15-2012)
Old 09-15-2012, 03:09 PM   #7
electures's Avatar
ALso Julius793 statement is a good idea. Use 2" mud rings and turn them sideways.
or
or
Old 09-15-2012, 03:18 PM   #8
Code05's Avatar
Rewards Points: 1,104
Works for me, or plastic extension rings or use these.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
jbfan (09-16-2012)
Old 09-15-2012, 03:19 PM   #9
how come they don't have these mud rings for single gang handy boxes? i already have a couple installed and it will be PIA to get them out and replace them with 1900 boxes
Old 09-15-2012, 03:25 PM   #10
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Plan accordingly my friend.
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
amakarevic (09-15-2012), Code05 (09-15-2012)
Old 09-15-2012, 03:25 PM   #11
Code05's Avatar
Use these then.
Old 09-15-2012, 03:27 PM   #12
Originally Posted by Code05 View Post
Use these then.
i think there was a problem with your attachment. at least i couldn't see it
nvrmnd -- can see now. sorry
can you post a link to amazon ? thanks
Old 09-15-2012, 03:27 PM   #13
electures's Avatar
Lot of good ideas from professionals. Nice
Old 09-15-2012, 03:30 PM   #14
hey Code05, can you please post a link where i can buy these mud rings you attached a picture of?
the logo on the pic looks like Amazon but i couldn't find it there.
thanks
Old 09-15-2012, 03:31 PM   #15
E2 Electrician
thanks
Home depot carries them.
Arlington box extensions... you can get them by other manufactures as well.
The Following User Says Thank You to stickboy1375 For This Useful Post:
No power in all three bathroom outlets hpdad Electrical 23 03-24-2012 01:51 PM
Grounding outlets... bigdaddyII Electrical 12 08-28-2011 03:22 PM
Baseboard Heater / Power Cord Problem channingg General DIY Discussions 8 10-02-2009 12:35 AM
Electrical - Outlets with no power jogan Electrical 5 05-05-2009 03:06 PM
Power to outlets but not enough? batesrt Electrical 5 02-04-2008 10:12 PM
