-   -   baseboard power outlets (http://www.diychatroom.com/f18/baseboard-power-outlets-156890/)
amakarevic 09-15-2012 01:55 PM
i need to have a couple of baseboard power outlets. the problem is, and i am using metal handy boxes with side braces, they are made to be flush with the drywall and not another layer on top of it (baseboard). so i was wondering if anyone knows of some special handy boxes that are made specifically for baseboard outlets that give it more offset between the brace and the edge of the box or is there a trick to it or something.
yeah, i can always leave the box flush with the drywall and recessed a little inside the baseboard but that kindof looks ugly, especially if you don't cut the faceplate opening on the baseboard 100% correct and without gaps around. which is hard to do.
or perhaps if there is a yoke adapter that would indent the outlet outside by an offset of 3/4" or can that simply be accomplished by not screwing the yoke screws all the way in and leaving them out by 3/4" and then accomplish firmness using the faceplate screwed to it and resting against the baseboard ?
thanks
Julius793 09-15-2012 01:58 PM
thanks
You can use a 1900 box with a 1" mud ring.
electures 09-15-2012 01:59 PM
thanks
Oldwork plastic boxes directly into the baseboard. That is how I do it.
amakarevic 09-15-2012 02:03 PM
the problem is that all receptacle installation must be done in the rough-in phase, i.e. boxes installed before drywall and baseboard. because then i won't be able to access the wiring.
amakarevic 09-15-2012 02:04 PM
any issues with using just a simple metal handy box with braces for stud (or in this case, sole plate) mounting with a mud ring?
electures 09-15-2012 02:07 PM
Just poke the wires out where they will be located. Tell the inspector you are going to oldwork the boxes into the baseboard. SHouldn't be a problem. See it done all the time in old homes, historical renovations, and such. That is also how I like to do it.
electures 09-15-2012 02:09 PM
ALso Julius793 statement is a good idea. Use 2" mud rings and turn them sideways.
http://www1.crouse-hinds.com/crouseh...es/MudRing.jpgor http://community.homedepot.com/t5/im...v=mpbl-1&px=-1
or
http://www.excess-supply.com/site/ca...31/2000-TB.jpg
Code05 09-15-2012 02:18 PM
Works for me, or plastic extension rings or use these.
http://i877.photobucket.com/albums/a...ZQsgCdUAFS.jpg
amakarevic 09-15-2012 02:19 PM
how come they don't have these mud rings for single gang handy boxes? i already have a couple installed and it will be PIA to get them out and replace them with 1900 boxes
stickboy1375 09-15-2012 02:25 PM
12 Attachment(s)
Plan accordingly my friend. :)
Code05 09-15-2012 02:25 PM
Use these then.
http://i877.photobucket.com/albums/a...N3cOxGuCdY.jpg
amakarevic 09-15-2012 02:27 PM
Originally Posted by Code05 (Post 1010455)
Use these then.
i think there was a problem with your attachment. at least i couldn't see it
nvrmnd -- can see now. sorry
can you post a link to amazon ? thanks
electures 09-15-2012 02:27 PM
Lot of good ideas from professionals. Nice
amakarevic 09-15-2012 02:30 PM
hey Code05, can you please post a link where i can buy these mud rings you attached a picture of?
the logo on the pic looks like Amazon but i couldn't find it there.
thanks
stickboy1375 09-15-2012 02:31 PM
12 Attachment(s)
thanks
Home depot carries them.
Arlington box extensions... you can get them by other manufactures as well.
