-   -   Baseboard Heaters (http://www.diychatroom.com/f18/baseboard-heaters-17237/)
matrix733 02-17-2008 08:52 PM
Baseboard Heaters
Is it code to run 4 or 3 500w (240v) baseboard heaters off one 22amp(two pole) rated thermostat on 12/3 romex?:huh:
junkcollector 02-17-2008 08:59 PM
A 20 amp circuit will easily handle 4 heaters of this size. (4x500w=2000w/240v=8.3A) A 15 amp circuit will suffice. Why the 12/3? The heaters are straight 240, so you only need 2 hot wires plus ground. 12/2 will work just fine. Be sure to reidentify the white as a "hot'' conductor.
chris75 02-17-2008 09:13 PM
Just a side note fixed electric heat must also be figured at 125%... so,
(4x500w=2000w*125%=2500w/240v=10.41A
matrix733 02-17-2008 10:48 PM
Thanks, I forgot that I did not need a neutral for the heaters.
