Baseboard Heater Wiring Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-06-2010, 08:32 AM   #16
joed's Avatar
Rewards Points: 13,752
The baseboard does NOT need a 12/3. 12/2 is fine. Baseboards don't use a neutral. The only need two wires + ground.
Old 10-06-2010, 08:57 AM   #17
Rewards Points: 730
Yes, I realize that. If I re-wire I'll use 12/2, even though I'm told 14/2 is fine. The only reason I'd use 12/3, is if I re-use the existing wiring. ...or if I use the junction box idea so that I can run a window a/c off the same circuit, as I believe they do require a neutral and 2 hots.
Master Brian is offline   Reply With Quote
Old 10-06-2010, 01:11 PM   #18
Rewards Points: 730
Well, some of my job just potentially got a little easier. It seems the only other outlet fed by the GFI is one outlet in the bedroom and the bedroom will likely be gutted of lathe and plaster this winter so it can be insulated and rocked. The best part is the wire supplying the bedroom outlet is easily accessible in the attic as it was lazily ran, so I could tie it into an outlet in the attic for now. The box for the GFI is extra deep, so it shouldn't be a problem to just make the BB Heater connections properly, for now, in that box. Much easier than running all new wiring!!
The best part is another, still active GFI, in the bathroom doesn't seem to trip, when the button is pushed. So, I'm guessing it needs to be replaced as I believe that feeds the receptacle by the sink! NICE!!!
Old 10-06-2010, 02:34 PM   #19
joed's Avatar
Bedroom and bathroom are not permitted under current to be on the same circuit. Bathroom must be a dedicated 20 amp circuit that feeds only the bathroom. Bedroom can have other items on it and MUST be AFCI protected.
Old 10-07-2010, 02:26 PM   #20
Rewards Points: 730
My guess was the way it was, was done long before current code and very possibly never inspected. My best guess is 80's +/- 5yrs. As for if I tied it into the attic circuit, it'd only be a temp solution until I could find the time to get it re-wired correctly and place the bathroom on it's own circuit.
Old 10-07-2010, 07:32 PM   #21
joed's Avatar
It may be legal if you leave it alone. However you said you were gutting the bedroom and running new cable. That means you need to meet current codes.
Old 10-07-2010, 09:28 PM   #22
Rewards Points: 730
When I gut the bedroom, it will meet current codes. I'm just saying for now, it'll have to work.... Most likely the bedroom, won't even be hooked back up until I gut it, unless I do it just for temporary power.
Wiring a 240V baseboard heater T-stat criggs Electrical 3 05-10-2010 08:27 PM
Wiring Question bahaisamurai Electrical 3 02-22-2009 11:06 AM
Baseboard radiator question timothy918 HVAC 6 11-29-2008 04:00 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
240/208 Heater wiring Question fburke Electrical 2 06-20-2005 12:09 PM
