Baseboard Heater Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 04-08-2013, 05:13 PM   #1
Baseboard heater wiring
Have two baseboard heaters; one each in separate bedrooms; heater #1 stays on (low) all the time; went to replace the thermostats in both rooms and found the wiring to be as shown on the attachment; heater #2 & thermostat work; heater #1 thermostat seems to have no effect on the baseboard unit. Any suggestions how I can get the wiring put right? Much appreciated.
Hikermann is offline   Reply With Quote
Old 04-08-2013, 07:01 PM   #2
joed's Avatar
Rewards Points: 13,766
According to that diagram the heater#1 has constant power and heater #2 requires both stats to be on for it to work. Take the black hot wire from the black and white connection on the left and connect it to the black black connection on the right.
Old 04-09-2013, 02:11 PM   #3
Round II Well ... got heater #1 / thermostat working fine (black from thermo connected to hot black), but for why I don't know the black wire coming from heater #2 / thermostat is hot -- meaning, if I connect it (and heater #1 black) to incoming hot, the breaker Does Not Like That!
Do appreciate any interpretation of status you can give.
Thanks.
Old 04-09-2013, 04:33 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You have two t-stats daisy chained, have your feed supply each T-stat, and the loads go to each baseboard heater respectfully....
Old 04-10-2013, 07:48 AM   #5
joed's Avatar
It should look like this. If that doesn't work then one of your heaters is bad or you don't have it wired like this.
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 09:30 AM
Min distance from baseboard hotwater heater capslock General DIY Discussions 2 05-25-2010 07:31 AM
Baseboard Heater: Can I wire it to plug into an AC recepticle? JBiz Electrical 3 12-01-2007 08:42 AM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 09:40 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 04:01 PM
