Baseboard Heater Wireless Thermostat - Electrical - DIY Chatroom Home Improvement Forum
Old 08-05-2011, 03:04 PM   #1
hohadcr's Avatar
Rewards Points: 308
baseboard heater wireless thermostat
Not sure if it exists.
I have a converted condo with baseboard electrical heaters. Right now, all the heaters have the thermostats on one side of it. So, right now, one has to bend over to turn the thermostats and it is hard to know if you turn it too much or not.
The right way is of course running some wires in the wall and add wired thermostats for each baseboard heater.
Being on a middle floor and thinking about saving hassle, I am hoping to find some thermostat that can be wirelessly controling the baseboard heaters.
I know there are wireless switches for 120V switches. Is there anything that is for 240V baseboard heaterss?
hohadcr is offline   Reply With Quote
Old 08-05-2011, 04:37 PM   #2
I=E/R
a7ecorsair's Avatar
If there was such a thing, you would have to mount a wireless relay in each unit in place of the existing thermostat.
I'm pretty sure there are digital thermostats for some units.
Here's one for the Cadet:
http://www.nextag.com/Cadet-Manufact...72/prices-html
a7ecorsair is offline   Reply With Quote
Old 08-05-2011, 04:53 PM   #3
Rewards Points: 6,652
http://www.honeywellcentral.com/ther...baseboard-heat
Old 08-05-2011, 05:05 PM   #4
hohadcr's Avatar
Rewards Points: 308
Hi, a7ecorsair, thanks, i think that is a possibility, if I change all the baseboarders to Cadet to fit the thermostats.
Hi, gregzoll, the link shows wired thermostats that I am trying to avoid
Old 08-05-2011, 06:06 PM   #5
You are not going to find any wireless thermostats for 240 volt baseboard heaters. In order to be wireless, you have to have a wired module to begin with.
double pole thermostat for kickspace heater lee12 Electrical 3 12-09-2010 12:52 PM
Baseboard Heater Size Advice nightheron Electrical 4 12-05-2010 07:33 PM
Min distance from baseboard hotwater heater capslock General DIY Discussions 2 05-25-2010 07:31 AM
Thermostat w/ wireless Remote Sensor Davidb6 HVAC 2 02-10-2009 07:45 PM
"sticky" gas water heater thermostat homer12 HVAC 7 01-22-2008 06:08 PM
