Baseboard Heater Under Window - Electrical - DIY Chatroom Home Improvement Forum
Old 10-07-2009, 07:54 PM   #1
Baseboard heater under window
For off-peak heating reasons my house was setup with storage heaters not electric baseboard heat in the upstairs living room or the down stairs family room. I am planning on removing the storage heater that is upstairs and putting in a hydronic electric baseboard 240v heater. I read it is best to place the baseboard under the window so that is what I plan to do. The problem I have is that there is a outlet in the wall almost exactly in the middle of the 6' wide set of windows. I read that you are not supposed to place electric baseboards under electrical outlets and this brings me to my point/question. Is it not safe or against code to put in a baseboard under an electical outlet?? Also how much difference would it make to not place the baseboard under the windows and put it on a different wall?
Just for some background info: this is a 1900sq foot bi-level house about 23 yrs old. Original windows which are not very good and we are located in North Dakota so very harsh winters.
Sorry for long post, thanks in advance for any help or advise.
Jason
jhubert is offline   Reply With Quote
Old 10-07-2009, 11:59 PM   #2
Electrical Contractor
kbsparky's Avatar
Originally Posted by jhubert View Post
....I read that you are not supposed to place electric baseboards under electrical outlets and this brings me to my point/question. Is it not safe or against code to put in a baseboard under an electical outlet??....
The Code has no direct restrictions on the placing of baseboard heaters under electrical outlets. It is more like a backdoor approach.
The problem many encounter is that section 110.3(B) states:
Installation and Use. Listed or labeled equipment shall be installed and used in accordance with any instructions included in the listing or labeling.
What you have to do here is actually read the manufacturer's instructions on the installation of the proposed heating units. I believe that certain electric hydronic heating units do not have such restrictions on mounting below electric outlets.
-KB
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
wiring a 240V baseboard heater 777 Electrical 10 05-17-2009 11:47 AM
Baseboard Heater: Can I wire it to plug into an AC recepticle? JBiz Electrical 3 12-01-2007 09:42 AM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 05:01 PM
