Baseboard Heater Thermostat Ground Wire ? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2011, 02:11 PM   #1
Hello,
I'm replacing all the Square D 240V electric baseboard heaters and thermostats in my house. I found out that they were recalled and are a fire hazard.. nice eh?
I have one question about the ground wire to the new Honeywell thermostat. The old Square D thermostat had a screw for the ground wire, and the load and common wires were screwed on as well. The new Honeywell thermostats have the (2) black and (2) red wires soldered on. There isn't a place to connect the ground. I've already wired up one of the bedrooms with the new heaters and the new thermostat and all works with the ground wire simpy twisted back onto the rest of the ground wires and wiring nut in the wall box. However, it's a tight fit to cram the new thermostat back into the wall box with the extra additional red and black wires from the thermostat, and (4) more wiring nuts from the load and common wiring. There was ample room with the old thermostat and simply screwing the load and common wires to the back of the thermostat.
My question is this... if the ground wire isn't needed for the new thermostat can I simply clip off the ground wires at the cable and remove the wiring nut so I'll have more room in the wall box ?
Thanks in advance
sciron is offline   Reply With Quote
Old 01-08-2011, 02:40 PM   #2
Scared Electrician
Saturday Cowboy's Avatar
NO most definitely not.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 01-08-2011, 02:51 PM   #3
Ok, so even though the ground wire isn't connected to the new thermostat, the ground wires from the load and common cables have to be connected in order to complete the ground circuit to the baseboard heater ?
Old 01-08-2011, 02:59 PM   #4
Mad Scientist
Correct, all ground wires entering a box must be connected together, and also connected to the box itself if it's a metal box.
McSteve is offline   Reply With Quote
The Following User Says Thank You to McSteve For This Useful Post:
sciron (02-19-2011)
Old 01-08-2011, 03:26 PM   #5
Ok.. thanks for the answers.
Old 01-08-2011, 11:32 PM   #6
Rewards Points: 1,442
Never clip off wires entering a box. Someone may find a use for them later.
The Following User Says Thank You to AllanJ For This Useful Post:
sciron (02-19-2011)
Old 02-19-2011, 06:28 PM   #7
Ended up putting all new baseboard heaters and thermostats in my house. Thanks for the advice and help.
Thermostat for electric baseboard heat 4 wire to 2 wire rossl56 HVAC 12 11-12-2014 05:10 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Ground wire behind baseboard disx2000 Electrical 8 05-30-2009 12:51 PM
wiring a 240V baseboard heater 777 Electrical 10 05-17-2009 11:47 AM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
